- From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Matching parameters of dependent types with common stem
- Date: Wed, 3 Oct 2012 15:51:11 +0000
- Accept-language: en-GB, en-US
Hi,
How could Spec be made to return the proposition
forall x : X, D x /\ L x?
Clearly, the way I've defined it is nonsense. However, I don't know how to
exploit the fact that parameters d and l are both dependent on parameter X.
Inductive Data : Set -> Type :=
Build_Data : forall X : Set, (X -> Prop) -> Data X.
Inductive Link : Set -> Type :=
Build_Link : forall X : Set, (X -> Prop) -> Link X.
Definition Spec (X : Set) (d : Data X) (l : Link X) : Prop :=
match d with Build_Data X D =>
match l with Build_Link X L =>
end
end.
Many thanks.
Regards,
Jeff.
Jeffrey Terrell
Department of Informatics
King's College, London
- [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Pierre Boutillier, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Adam Chlipala, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Robbert Krebbers, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, AUGER Cédric, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/04/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, AUGER Cédric, 10/04/2012
