coq-club - Re: [Coq-Club] Matching parameters of dependent types with common stem
  • From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
  • To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Matching parameters of dependent types with common stem
  • Date: Wed, 3 Oct 2012 16:56:11 +0000
  • Accept-language: en-GB, en-US
Dear Pierre,
Thanks for your response. However, your definition of Spec produced the
following error (term "D" is the one after end).
Error:
In environment
X : Set
d : Data X
l : Link X
X0 : Set
D : X0 -> Prop
The term "D" has type "X0 -> Prop" while it is expected to have type
"X -> Prop".
I'm running Coq version 8.3 (December 2011).
Regards,
Jeff.
Jeffrey Terrell
Department of Informatics
King's College, London
On 3 Oct 2012, at 17:15, Pierre Boutillier wrote:
> Hi,
> Your problem is a good example to describe what has been improved in the
> pattern matching compiler in Coq 8.4 and why we are still in the middle of
> something.
> Your problem basically is that you want to keep the link between the type
> of d and l while you are matching over d and then l and D while you are
> matching over l
> In coq 8.4 you sometime can do it by saying
>> match d,l with Build_Data X0 D,l' =>
> and l' is not l even is you do not destruct it. It is a copy of l : Link X
> in Link X0
> But it does not work every time and you still sometime need to write the
> underlying commutative cut ourself as
>> match l' with Build_Link X L => fun D' =>
>> …. end D
> (Situations where you even have to write explicitly the type annotation
> occur)
> In the end the term you're trying to write is
> --8<----
> Inductive Data : Set -> Type :=
> Build_Data : forall X : Set, (X -> Prop) -> Data X.
> Inductive Link : Set -> Type :=
> Build_Link : forall X : Set, (X -> Prop) -> Link X.
> Definition Spec (X : Set) (d : Data X) (l : Link X) : Prop :=
> match d,l with Build_Data X D,l' =>
> forall x : X, D' x /\ L x
> end D
> end.
> --8<-----
> Hugo Herbelin and I are working to allow you to write
> match d,l with Build_Data X D, Build_Link X L =>
> forall x : X, D x /\ L x
> end.
> and this will be in the change log (CF: Cedric and Daniel) :-p.
> Pierre B.
> Le 3 oct. 2012 à 17:51, "Terrell, Jeffrey"
> a écrit :
>> Hi,
>> How could Spec be made to return the proposition
>> forall x : X, D x /\ L x?
>> Clearly, the way I've defined it is nonsense. However, I don't know how to
>> exploit the fact that parameters d and l are both dependent on parameter X.
>> match d with Build_Data X D =>
>> match l with Build_Link X L =>
>> end
>> end.
>> Many thanks.
>> Regards,
>> Jeff.
>> Jeffrey Terrell
