- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Matching parameters of dependent types with common stem
- Date: Wed, 3 Oct 2012 18:15:56 +0200
Hi,
Your problem is a good example to describe what has been improved in the
pattern matching compiler in Coq 8.4 and why we are still in the middle of
something.
Your problem basically is that you want to keep the link between the type of
d and l while you are matching over d and then l and D while you are matching
over l
In coq 8.4 you sometime can do it by saying
> match d,l with Build_Data X0 D,l' =>
and l' is not l even is you do not destruct it. It is a copy of l : Link X in
Link X0
But it does not work every time and you still sometime need to write the
underlying commutative cut ourself as
> match l' with Build_Link X L => fun D' =>
> …. end D
(Situations where you even have to write explicitly the type annotation occur)
In the end the term you're trying to write is
--8<----
Inductive Data : Set -> Type :=
Build_Data : forall X : Set, (X -> Prop) -> Data X.
Inductive Link : Set -> Type :=
Build_Link : forall X : Set, (X -> Prop) -> Link X.
Definition Spec (X : Set) (d : Data X) (l : Link X) : Prop :=
match d,l with Build_Data X D,l' =>
forall x : X, D' x /\ L x
end D
end.
--8<-----
Hugo Herbelin and I are working to allow you to write
match d,l with Build_Data X D, Build_Link X L =>
forall x : X, D x /\ L x
end.
and this will be in the change log (CF: Cedric and Daniel) :-p.
Pierre B.
Le 3 oct. 2012 à 17:51, "Terrell, Jeffrey"
a écrit :
> Hi,
> How could Spec be made to return the proposition
> forall x : X, D x /\ L x?
> Clearly, the way I've defined it is nonsense. However, I don't know how to
> exploit the fact that parameters d and l are both dependent on parameter X.
> match d with Build_Data X D =>
> match l with Build_Link X L =>
> end
> end.
> Many thanks.
> Regards,
> Jeff.
> Jeffrey Terrell
> Department of Informatics
> King's College, London
- [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Pierre Boutillier, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Adam Chlipala, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Robbert Krebbers, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, AUGER Cédric, 10/03/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, Terrell, Jeffrey, 10/04/2012
- Re: [Coq-Club] Matching parameters of dependent types with common stem, AUGER Cédric, 10/04/2012
