coq-club - Re: [Coq-Club] Matching parameters of dependent types with common stem
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Matching parameters of dependent types with common stem
  • Date: Wed, 3 Oct 2012 18:21:47 +0200
Le Wed, 3 Oct 2012 15:51:11 +0000,
"Terrell, Jeffrey"
<jeffrey.terrell AT kcl.ac.uk>
a écrit :
> Hi,
> How could Spec be made to return the proposition
> forall x : X, D x /\ L x?
> Clearly, the way I've defined it is nonsense. However, I don't know
> how to exploit the fact that parameters d and l are both dependent on
> parameter X.
> Inductive Data : Set -> Type :=
> Build_Data : forall X : Set, (X -> Prop) -> Data X.
> Inductive Link : Set -> Type :=
> Build_Link : forall X : Set, (X -> Prop) -> Link X.
> Definition Spec (X : Set) (d : Data X) (l : Link X) : Prop :=
> match d with Build_Data X D =>
> match l with Build_Link X L =>
> end
> end.
> Many thanks.
> Regards,
> Jeff.
> Jeffrey Terrell
> Department of Informatics
> King's College, London
I guess you want to do this:
let D : X -> Prop := match d with Build_Data X D => D end in
let L : X -> Prop := match l with Build_Link X L => L end in
forall x : X, D x /\ L x.
Note that I assume your true stuff is more complex than your example.
If not, there is something easier:
Inductive Data (X : Set) : Type :=
Build_Data : (X -> Prop) -> Data X.
Inductive Link (X : Set) : Type :=
Build_Link : (X -> Prop) -> Link X.
And then you do not have dependant type anymore.
