- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>, AUGER Cédric <sedrikov AT gmail.com>, coq-club <coq-club AT inria.fr>, Hugo Herbelin <Hugo.Herbelin AT inria.fr>
- Subject: Re: [Coq-Club] Proof irrelevance
- Date: Sun, 25 Nov 2012 07:57:43 +0100
Here is an attempt at a systematic explanation:
A term of a (possibly recursive) singleton type does not have any run-time content and can be safely erased during extraction, because at run-time all terms are closed, thus a singleton type does really have at most one canonical inhabitant.
At type-checking type, the situation is different. There are infinitely many open terms that inhabit a singleton type. The question is whether they bear different information. This is indeed the case at least for recursive singleton types and for non-linear dependent families such as the identity type.
The information contained in h : Acc R e, for instance, is how often you may unfold a function defined by well-founded recursion on relation R called at term e with accessibility proof h.
As discussed by you below, if you have eta-expansion for recursive singleton types, then you destroy this information, justifying proof irrelevance, but you also destroy strong normalization. If you do not have eta-expansion, you destroy subject reduction if you accept proof irrelevance (as I demonstrated).
Things which do contain (computational) information cannot be made irrelevant (unless you take away means to eliminate them, but then, in my opinion, you also remove the information).
So, we cannot have proof irrelevant for all of Prop unless we restrict singleton elimination to propositions whose proofs have really no content. This excludes singleton elimination for some recursive propositions like Acc and for non-linear families such as the identity type.
A systematic solution is to have a sub-universe of Prop that contains only propositions whose proofs you are either not allowed to eliminate (they are not singleton propositions) or which do not have any content at type-checking time.
Effectively, there is already a sub-universe of Prop: singleton props. One could treat the sub-universe of proof-irrelevant props similar: whenever the type checker compares two proofs for definitional equality, it can immediately succeed if the proposition belongs to this sub-universe. (Internally one could try to be smarter and keep track of the sub-universes.)
@Hugo, do I understand your proposal correctly, that you want proof irrelevance for those propositions P that have a closed proof?
I guess or would also want proof irrelevance for non-recursive empty propositions, or?
Cheers,
Andreas
On 24.11.12 6:58 PM, Hugo Herbelin wrote:
Hi,
Look at it this way: definitional proof irrelevance for Acc in Prop can
hold only if singleton elimination is forbidden for it still.
Otherwise, the definitional equational theory should validate
[forall a : Acc, Fix F a = Fix F (Acc_intro a) = F [Fix F a]]. Clearly
[Fix F a = F [Fix F a]] will be hard to handle as a terminating rewrite
system, it leads to infinite reductions.
Indeed, proof-irrelevance would imply that any "fix" is definitionally
equal to any arbitrary deep unfolding of it. How much this would
damage the decidability of the type-checking, it is unclear to me.
For type-checking, don't we just need an algorithm that, for any two
expressions a and b involving fixpoints over Acc proofs, is able to
decide the up-to-proof-irrelevance convertibility of a and b by
needing only a finite number of unfoldings of these fixpoints in a and b.
Is it really clear that such an algorithm does not exist?
The problem is that this "finite" number of unfoldings is unknown and
in an incoherent context you could certainly craft a conversion problem
that would lead the algorithm to infinitely unfold the fix.
Let's try:
Fix_F full_rel (fun F a -> if F a = 0 then 0 else 0) acc a \conv 0 <->
(if Fix_F full_rel (fun F a -> if F a...) acc a = 0 then 0 else 0) a acc \conv 0
(if (if Fix_F full_rel (fun F a -> if F a...) acc a = 0 then 0 else 0) = 0
then 0 else 0) \conv 0 …
Basically this reduces to the halting problem, no?
I agree (Guillaume Melquiond actually convinced me offline that the
halting problem was simulable in an inconsistent context). I know this
topic has been discussed in length already several years ago but it
happens I'm still confused about it.
So, would it make sense to have "limited" proof-irrelevance which
would only make equal proofs known to be inhabitable (for some
syntactic criterion of inhabitability, based on what the user already
proved to be inhabitable)? This would rule out the ability to unfold
fixpoints whose termination is not justified by a model of Coq. But
this would still allow to make definitionally equal most of the proofs
it is convenient to identify in practice (like two proofs of "x<y", or
two proofs of "Acc lt x").
Hugo
On Fri, Nov 23, 2012 at 11:41:00AM -0500, Matthieu Sozeau wrote:
Hi,
On 22 nov. 2012, at 03:51, AUGER Cédric
wrote:
Le Thu, 22 Nov 2012 01:42:48 +0100,
Andreas Abel
<andreas.abel AT ifi.lmu.de>
a écrit :
Adding proof irrelevance to breaks Coq breaks subject reduction,
because of singleton elimination. Proof irrelevance equates all
accessibility proofs, but accessibility proofs are used to certify
termination. Here is an exploit:
I do not really see your point with an example which is absurd (I mean
that with your 'Variable h', you can prove False, so that I could
prove 'g h = true' as well).
Indeed Variable h : Acc R 1. is equivalent to False already,
but subject reduction should hold in any context as we do
reduction under arbitrary contexts.
For subject reduction, I have heard that
not all Coq constructions respects it, so adding one wouldn't be that
much annoying.
Really? I would be less annoyed if everything did respect SR.
and last, if I well understood, adding 'eta' for
'unit_types' (eq, Acc, True, …) would repair this subject reduction.
The only way to fix the non-termination would be to say that singleton
elimination should be allowed for computationally-irrelevant types only,
which removes Acc's elimination into Set/Type. Then the issue that Andreas
mentioned goes away as well.
I have a patch that adds proof-irrelevance with the additional restriction
that Prop </= Type (but Prop : Type(1) still). It's not up to date with
the trunk though, but I can send it to you if you want to try it.
-- Matthieu
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
http://www2.tcs.ifi.lmu.de/~abel/
- [Coq-Club] Proof irrelevance, AUGER Cédric, 11/21/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/22/2012
- Re: [Coq-Club] Proof irrelevance, AUGER Cédric, 11/22/2012
- Re: [Coq-Club] Proof irrelevance, Matthieu Sozeau, 11/23/2012
- Re: [Coq-Club] Proof irrelevance, Hugo Herbelin, 11/23/2012
- Re: [Coq-Club] Proof irrelevance, Matthieu Sozeau, 11/24/2012
- Re: [Coq-Club] Proof irrelevance, Hugo Herbelin, 11/24/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/25/2012
- Re: [Coq-Club] Proof irrelevance, Hugo Herbelin, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Guillaume Melquiond, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Arnaud Spiwack, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Frederic Blanqui, 11/27/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/27/2012
