coq-club - Re: [Coq-Club] Proof irrelevance
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • Cc: Hugo Herbelin <Hugo.Herbelin AT inria.fr>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proof irrelevance
  • Date: Mon, 26 Nov 2012 11:18:42 +0100
Well, I don't think soundness is the issue here, but rather completeness. What you have in mind is an algorithm which checks a smaller relation than convertibility (mostly because it's not a congruence). The result would probably be some loss in subject reduction (you're probably able to construct, piecewise a proof of p1 = p2 : Acc R x, which reduces to a reflexivity proof which does not typecheck). I'm not convinced either that it would terminate anyway, but it's plausible indeed.
On 26 November 2012 11:09, Guillaume Melquiond <guillaume.melquiond AT inria.fr> wrote:
Le lundi 26 novembre 2012 à 10:43 +0100, Arnaud Spiwack a écrit :
>         If you always need match or
>         fix, I am under the impression that propositional variables do
>         not
>         matter since their values cannot be matched upon.
> Well, you seem to be missing Hugo's point here. By the lemma above, f1
> (Acc R x) p1 p2 and f2 (Acc R x) p1 p2 are convertible. Hence any two
> proofs of Acc R x are convertible, hence full proof-irrelevance.
Rather than proof-irrelevance, my concern was about having a
convertibility check that does terminate in all cases (that is, no
reduction to the halting problem). And I think that is what Hugo was
seeking too. My intuition still stands: I think you do not have to
exclude propositional variables from the algorithm. Now, the algorithm
might not give a sound answer due to proof irrelevance, but I am hardly
competent on such theoretical issues; I prefer to leave them to Andreas
and others.
Best regards,
Guillaume
