- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proof irrelevance
- Date: Sun, 25 Nov 2012 08:05:22 +0100
On 22.11.12 9:51 AM, AUGER Cédric wrote:
Variable pi_refl : h = h'.
Definition p : g h = false
:= resp h h' pi_refl.
(* If we have proof irrelevance, then pi_refl can be replaced by
eq_refl. But then p reduces to eq_refl, but eq_refl does not have
type g h = false,
because g h does not reduce.
Subject reduction is lost (once more).
I doubt you find it interesting, and it does not mean much, but I
instantiated pi_refl, to see what would be the outputs.
Definition pi_refl : h = h'.
exact ((eq_refl h : (h:Acc R 1:Prop) = (h:Acc R 1:Prop))
: (h:Acc R 1:Prop) = (h':Acc R 1:Prop)).
Defined.
Print pi_refl.
pi_refl =
(eq_refl
:(h:Acc R 1:Prop) = (h:Acc R 1:Prop))
:(h:Acc R 1:Prop) = (h':Acc R 1:Prop)
: h = h'
Eval compute in p.
= eq_refl
: g h = false
That is exactly the point, because if you
Check (eq_refl : g h = false)
then Coq (including your version) will say no.
Cheers,
Andreas
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
- Re: [Coq-Club] Proof irrelevance, (continued)
- Re: [Coq-Club] Proof irrelevance, Guillaume Melquiond, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Hugo Herbelin, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Arnaud Spiwack, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/26/2012
- Re: [Coq-Club] Proof irrelevance, Frederic Blanqui, 11/27/2012
- Re: [Coq-Club] Proof irrelevance, Andreas Abel, 11/27/2012
- Re: [Coq-Club] Proof irrelevance, Frédéric Blanqui, 11/27/2012
