- To: Yucheng Zhang <yczhang89 AT gmail.com>
- Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Performing tactics on each of the matched hypothesis
- Date: Wed, 28 Nov 2012 02:58:02 +0000
Hi Yucheng,
Here is a potential solution: maintaining a list of values
on which inversion was already performed and skip them
next time we encounter them.
This way you should avoid looping forever.
Require Import List.
Inductive P : nat -> Prop :=
p0 : P 0.
(* here we have a **syntactic** search for n in the list ns *)
Ltac is_in_dec n ns := match ns with
| nil => false
| n :: _ => true
| _ :: ?tl => is_in_dec n tl
end.
(* Here the first case looks for new values by failing on old ones,
and the catch-all one allows the tactics to succeed when all the
work has been done.
cf. this bit of cpdt for more details on the behaviour of the first
Ltac inverse_P ns := match goal with
| [ H: P ?x |- _ ] =>
let test := is_in_dec x ns in
match constr:test with
| true => fail
| false => inversion H ; inverse_P (x :: ns)
end
| _ => idtac ""
end.
(* Finally an example *)
Goal forall x y z, P x -> P y -> P z.
intros.
inverse_P (@nil nat).
Cheers,
gallais
On 28 November 2012 01:41, Yucheng Zhang <yczhang89 AT gmail.com> wrote:
On Nov 27, 2012, at 8:49 PM, AUGER Cédric <sedrikov AT gmail.com> wrote:Thanks for the detailed answer.
> I do not know if there is a better way, but I would tend to "clear H"
> instead of "move H at top" (or rather 'at bottom', I think).
> Most of the time, I do not want to keep the original hypothesis.
> So maybe a
> Ltac cleanP :=
> match goal with [ H : P _ |- _ ] => inversion H; clear H; subst end.
> would help. (Note: the subst may not do what you wish, since it would
> use all already present equalities)
>> H1 : P x
>> H2 : P y
>> H3 : P z
>> Q
> repeat cleanP. (* alternatively 'do 3 cleanP.' *)
> If your P predicate is recursive, you will encounter problems with
> tactic called endlessly.
I am not satisfied with the solution though, as my P predicate is indeed
recursive, and the number of P hypotheses is not known in advance. (I should
have formulated my question more accurately..)
Maybe a solution is 'do 5 cleanP', where 5 is an arbitarily chosen finite
number that is large enough, but this looks not so elegant.
- [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, AUGER Cédric, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, gallais, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Thomas Braibant, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/29/2012
