- To: Yucheng Zhang <yczhang89 AT gmail.com>
- Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Performing tactics on each of the matched hypothesis
- Date: Wed, 28 Nov 2012 10:37:10 +0000
Artisanal bug fix: name the hypotheses created by inversion and
if they are Ps then add their argument to the watch list. This makes
for a really ad-hoc solution and I'd be curious to see if it's possible
to build a more reusable one.
I guess it's possible in Ocaml (?) but what about pure Ltac?
Require Import List.
Inductive P : nat -> Prop :=
p0 : P 0
| p1 : forall n, P n -> P (S n).
(* here we have a **syntactic** search for n in the list ns *)
Ltac is_in_dec n ns := match ns with
| nil => false
| n :: _ => true
| _ :: ?tl => is_in_dec n tl
end.
(* Here the first case looks for new values by failing on old ones,
and the catch-all one allows the tactics to succeed when all the
work has been done.
cf. this bit of cpdt for more details on the behaviour of the first
Ltac inverse_P ns := match goal with
| [ H: P ?x |- _ ] =>
let test := is_in_dec x ns in
match constr:test with
| true => fail
| false =>
let H' := fresh "H" in
let m' := fresh "m" in
inversion H as [H' | m' H'] ;
match type of H' with
| P ?z => inverse_P (z :: x :: ns)
| _ => inverse_P (x :: ns)
end
end
| _ => idtac ""
end.
(* Finally an example *)
Goal forall x y z, P x -> P y -> P z.
intros.
inverse_P (@nil nat).
gallais
On 28 November 2012 05:55, Yucheng Zhang <yczhang89 AT gmail.com> wrote:
Inductive P : nat -> Prop :=| p1 : forall n, P n -> P (S n).
p0 : P 0
- [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, AUGER Cédric, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, gallais, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Thomas Braibant, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/29/2012
