- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: gallais <guillaume.allais AT ens-lyon.org>
- Cc: Yucheng Zhang <yczhang89 AT gmail.com>, AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Performing tactics on each of the matched hypothesis
- Date: Wed, 28 Nov 2012 13:56:20 +0100
On Wed, Nov 28, 2012 at 11:37 AM, gallais
wrote:
> I guess it's possible in Ocaml (?) but what about pure Ltac?
It happens that I wrote such a plugin once, for demo purpose (I do not
remember exactly what the context was...) You can find it at [1] amd
it should work out of the box with coq 8.4.
Disclaimer. There is one wrinkle here: in this plugin, I made an
arbitrary choice in the way I iterate over the hypotheses, and there
are many other possible strategies and choices. I would be interested
to discuss this with people, and see what would be the right strategy
in their case.
Yet, I implemented the example that was discussed in this thread, and
benchmarked my plugin and Guillaume's Ltac solution using the
following benchmark using a benchmark in which there are [n] instances
of [P x_i] to invert.
For n = 10, the Ltac code runs in 10s, the plugin in 1.5s.
For n = 12, the Ltac code runs in 170s, the plugin in 12s.
I think the results are pretty clear here. Unfortunately, writing plugin is:
- not well documented,
- requires a bit of boilerplate,
- and it may be the case that plugins need to be adapted in depth when
the next release of Coq come out.
Nevertheless, I really think that it is worth it to build efficient
tactics (and whose implementation is often simpler than their Ltac
counterparts).
Thomas
[1] github https://github.com/braibant/apply-once
- [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, AUGER Cédric, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, gallais, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Thomas Braibant, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/29/2012
