- To: gallais <guillaume.allais AT ens-lyon.org>
- Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Performing tactics on each of the matched hypothesis
- Date: Wed, 28 Nov 2012 13:55:28 +0800
On Nov 28, 2012, at 10:58 AM, gallais
wrote:
> Hi Yucheng,
> Here is a potential solution: maintaining a list of values
> on which inversion was already performed and skip them
> next time we encounter them.
> This way you should avoid looping forever.
> Require Import List.
> Inductive P : nat -> Prop :=
> p0 : P 0.
> (* here we have a **syntactic** search for n in the list ns *)
> Ltac is_in_dec n ns := match ns with
> | nil => false
> | n :: _ => true
> | _ :: ?tl => is_in_dec n tl
> end.
> (* Here the first case looks for new values by failing on old ones,
> and the catch-all one allows the tactics to succeed when all the
> work has been done.
> cf. this bit of cpdt for more details on the behaviour of the first
> match: http://adam.chlipala.net/cpdt/html/Match.html *)
> Ltac inverse_P ns := match goal with
> | [ H: P ?x |- _ ] =>
> let test := is_in_dec x ns in
> match constr:test with
> | true => fail
> | false => inversion H ; inverse_P (x :: ns)
> end
> | _ => idtac ""
> end.
> (* Finally an example *)
> Goal forall x y z, P x -> P y -> P z.
> intros.
> inverse_P (@nil nat).
> Cheers,
> gallais
Thanks!
It still goes into an infinite loop when the P predicate is recursive, e.g.
p0 : P 0
| p1 : forall n, P n -> P (S n).
This is only caused by the particular behaviour of 'inversion' tactic, so the
solution with maintaining a list may fit other situations nicely.
- [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, AUGER Cédric, 11/27/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, gallais, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Thomas Braibant, 11/28/2012
- Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Yucheng Zhang, 11/29/2012
