- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A proposal for a new kind of hints in Coq
- Date: Wed, 09 Jan 2013 16:30:32 +0200
- Envelope-from: porton AT yandex.ru
09.01.2013, 15:52, "Victor Porton"
<porton AT narod.ru>:
> The following is my proposal to add a new feature to Coq:
> Add and remove hints to a new kind of hints databases which I call
> "general" hints:
> Create General Hint <db>.
> [Local] General Hint <db>: <term-1>...<term-n>. (* add n terms to the DB *)
> [Local] Remove General Hint <db>.
Sorry,
Remove General Hint <db>: <term-1>...<term-n>.
> Now for a hint database named "dual_order" it can be used as follows (with
> $ used to refer to general hints DB):
> rewrite $dual_order
> would be equivalent to
> rewrite <term-1>, ..., <term-n>
> (if the DB "dual_order" contains <term-1>, ..., <term-n>)
> and maybe likewise in other tactics, I haven't yet considered that in
> details.
> We could also mix references to general hints databases with plain IDs like
> this:
> rewrite $dual_order, my_rule, $dual_category.
> My proposal is not perfect. The following are the deficiencies:
> 1. I provide no mean to control that all hints inserted in such hints
> databases are setoid equalities.
> 2. There should be a way to pass "references" to general hint databases,
> that is variables containing a reference to a hint database. This way for
> example code for both order duality and categorical duality can be shared.
> The best thing for this I invented for now is double-dollar notation like:
> rewrite $$dbref.
> I haven't yet realized what database reference should be. Should these be
> simply strings (with database names)?
> Finally, if nobody is willing to implement this, I TREAT you that I will
> learn ML and do it myself!
Oh, certainly I THREAT not treat. :-)
Victor Porton - http://portonvictor.org
- [Coq-Club] A proposal for a new kind of hints in Coq, Victor Porton, 01/09/2013
- Re: [Coq-Club] A proposal for a new kind of hints in Coq, Victor Porton, 01/09/2013
- Re: [Coq-Club] A proposal for a new kind of hints in Coq, Vincent Siles, 01/09/2013
