- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A proposal for a new kind of hints in Coq
- Date: Wed, 09 Jan 2013 16:53:26 +0200
- Envelope-from: porton AT yandex.ru
09.01.2013, 16:30, "Victor Porton"
<porton AT narod.ru>:
> 09.01.2013, 15:52, "Victor Porton"
>> The following is my proposal to add a new feature to Coq:
>> Add and remove hints to a new kind of hints databases which I call
>> "general" hints:
>> Create General Hint <db>.
>> [Local] General Hint <db>: <term-1>...<term-n>. (* add n terms to the DB
>> [Local] Remove General Hint <db>.
> Sorry,
> Remove General Hint <db>: <term-1>...<term-n>.
>> Now for a hint database named "dual_order" it can be used as follows
>> (with $ used to refer to general hints DB):
>> rewrite $dual_order
>> would be equivalent to
>> rewrite <term-1>, ..., <term-n>
>> (if the DB "dual_order" contains <term-1>, ..., <term-n>)
>> and maybe likewise in other tactics, I haven't yet considered that in
>> details.
>> We could also mix references to general hints databases with plain IDs
>> like this:
>> rewrite $dual_order, my_rule, $dual_category.
>> My proposal is not perfect. The following are the deficiencies:
>> 1. I provide no mean to control that all hints inserted in such hints
>> databases are setoid equalities.
>> 2. There should be a way to pass "references" to general hint databases,
>> that is variables containing a reference to a hint database. This way for
>> example code for both order duality and categorical duality can be shared.
>> The best thing for this I invented for now is double-dollar notation like:
>> rewrite $$dbref.
>> I haven't yet realized what database reference should be. Should these be
>> simply strings (with database names)?
>> Finally, if nobody is willing to implement this, I TREAT you that I will
>> learn ML and do it myself!
> Oh, certainly I THREAT not treat. :-)
We could also do things like
apply $dual_order
but that would not work as desired because apply applies terms in order, so
that each term should be applied.
We probably need a new tactic for general hint databases... I'm not sure
about this.
Victor Porton - http://portonvictor.org
- [Coq-Club] A proposal for a new kind of hints in Coq, Victor Porton, 01/09/2013
- Re: [Coq-Club] A proposal for a new kind of hints in Coq, Victor Porton, 01/09/2013
- Re: [Coq-Club] A proposal for a new kind of hints in Coq, Vincent Siles, 01/09/2013
