coq-club - Re: [Coq-Club] A proposal for a new kind of hints in Coq
  • To: coq-club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] A proposal for a new kind of hints in Coq
  • Date: Wed, 09 Jan 2013 19:03:45 +0200
  • Envelope-from: porton AT yandex.ru
Oh, I noticed that we can use [Hint Rewrite] to manage what I previously
called general hints, that is we can share databases for autorewrite and for
general hints.
The only thing needed to change in ML is to add $-references to "rewrite"
tactic. Or should we create a new tactic specifically for this? I think we'd
better to extend "rewrite" tactic with $-notation.
09.01.2013, 16:54, "Victor Porton"
<porton AT narod.ru>:
> 09.01.2013, 16:30, "Victor Porton"
>>  09.01.2013, 15:52, "Victor Porton"
>>>   The following is my proposal to add a new feature to Coq:
>>>   Add and remove hints to a new kind of hints databases which I call
>>> "general" hints:
>>>   Create General Hint <db>.
>>>   [Local] General Hint <db>: <term-1>...<term-n>. (* add n terms to the
>>> DB *)
>>>   [Local] Remove General Hint <db>.
>>  Sorry,
>>  Remove General Hint <db>: <term-1>...<term-n>.
>>>   Now for a hint database named "dual_order" it can be used as follows
>>> (with $ used to refer to general hints DB):
>>>   rewrite $dual_order
>>>   would be equivalent to
>>>   rewrite <term-1>, ..., <term-n>
>>>   (if the DB "dual_order" contains <term-1>, ..., <term-n>)
>>>   and maybe likewise in other tactics, I haven't yet considered that in
>>> details.
>>>   We could also mix references to general hints databases with plain IDs
>>> like this:
>>>   rewrite $dual_order, my_rule, $dual_category.
>>>   My proposal is not perfect. The following are the deficiencies:
>>>   1. I provide no mean to control that all hints inserted in such hints
>>> databases are setoid equalities.
>>>   2. There should be a way to pass "references" to general hint
>>> databases, that is variables containing a reference to a hint database.
>>> This way for example code for both order duality and categorical duality
>>> can be shared. The best thing for this I invented for now is
>>> double-dollar notation like:
>>>   rewrite $$dbref.
>>>   I haven't yet realized what database reference should be. Should these
>>> be simply strings (with database names)?
>>>   Finally, if nobody is willing to implement this, I TREAT you that I
>>> will learn ML and do it myself!
>>  Oh, certainly I THREAT not treat. :-)
> We could also do things like
> apply $dual_order
> but that would not work as desired because apply applies terms in order, so
> that each term should be applied.
> We probably need a new tactic for general hint databases... I'm not sure
> about this.
> Victor Porton - http://portonvictor.org
