- From: "Patricia Peratto" <psperatto AT adinet.com.uy>
- To: "coqclub" < coq-club AT inria.fr>
- Subject: [Coq-Club] if with different types
- Date: Mon, 11 Feb 2013 18:23:28 -0200
Is it possible to define an if _expression_
that gives values of different types in cases true and false? For example, I can define the following
_ifT _expression_ Definition _ifT
(A:Type)(b:bool)(e1:A)(e2:A):A
:= bool_rect (fun (b:bool) => A) e1 e2 b. and using it I can define as type:
Definition type1 (b:bool) : Set :=
_ifT Set b nat bool. Now I want to define a function that
gives O in case b is true and gives true in case b is false. I have done the following definition:
Definition function1 : forall (b:bool),(type1
b):=
fun (b:bool) => _ifT (type1 b) b O true. But I get the error message
Error: In environment
b : bool The term "0" has type "nat" while it is expected to have type "type1 b". The question is how can I define function1 (using
if).
- [Coq-Club] if with different types, Patricia Peratto, 02/11/2013
- Re: [Coq-Club] if with different types, Maxime Dénès, 02/11/2013
- Re: [Coq-Club] if with different types, Pierre-Marie Pédrot, 02/12/2013
- <Possible follow-up(s)>
- Re: [Coq-Club] if with different types, J. Ian Johnson, 02/11/2013
