coq-club - Re: [Coq-Club] if with different types
  • To: Patricia Peratto <psperatto AT adinet.com.uy>
  • Cc: coqclub <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] if with different types
  • Date: Mon, 11 Feb 2013 15:31:53 -0500 (EST)
IMO, the semantics of if in Coq is terrible. You want to use match just about
anywhere.
Secondly, there are no "untagged unions" in Coq, so you have to take off your
Lisper hat and put on a crown of thorns if you want to program that way. All
unions must be explicitly tagged.
In your case you might want to even propagate information learned from the if
from the returned value. You don't get that for free either. You have to pair
the result with a proof witness.
-Ian
----- Original Message -----
To: "coqclub"
Sent: Monday, February 11, 2013 3:23:28 PM GMT -05:00 US/Canada Eastern
Subject: [Coq-Club] if with different types
Is it possible to define an if expression
that gives values of different types in
cases true and false?
For example, I can define the following
_ifT expression
Definition _ifT (A:Type)(b:bool)(e1:A)(e2:A):A
:= bool_rect (fun (b:bool) => A) e1 e2 b.
and using it I can define as type:
Definition type1 (b:bool) : Set :=
_ifT Set b nat bool.
Now I want to define a function that
gives O in case b is true and gives
true in case b is false.
I have done the following definition:
Definition function1 : forall (b:bool),(type1 b):=
fun (b:bool) => _ifT (type1 b) b O true.
But I get the error message
Error: In environment
b : bool
The term "0" has type "nat" while it is expected to have type "type1 b".
The question is how can I define function1 (using if).
