coq-club - Re: [Coq-Club] if with different types
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] if with different types
  • Date: Mon, 11 Feb 2013 21:35:15 +0100
Hello,
Your definition of _ifT enforces that e1 and e2 have the same type.
However, you could define function1 as follows:
Definition function1 (b : bool) :=
if b return (if b then nat else bool) then O else true.
The "return" clause specifies the type you want to return, which will itself depend on the value of b.
Hope it helps,
Maxime.
On 11/02/2013 21:23, Patricia Peratto wrote:
Is it possible to define an if expression
that gives values of different types in
cases true and false?
For example, I can define the following
_ifT expression
Definition _ifT (A:Type)(b:bool)(e1:A)(e2:A):A
:= bool_rect (fun (b:bool) => A) e1 e2 b.
and using it I can define as type:
Definition type1 (b:bool) : Set :=
_ifT Set b nat bool.
Now I want to define a function that
gives O in case b is true and gives
true in case b is false.
I have done the following definition:
Definition function1 : forall (b:bool),(type1 b):=
fun (b:bool) => _ifT (type1 b) b O true.
But I get the error message
Error: In environment
b : bool
The term "0" has type "nat" while it is expected to have type "type1 b".
The question is how can I define function1 (using if).
