coq-club - Re: [Coq-Club] if with different types
  • From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
  • To: Patricia Peratto <psperatto AT adinet.com.uy>
  • Cc: coqclub <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] if with different types
  • Date: Tue, 12 Feb 2013 11:51:40 +0100
On 11/02/2013 21:31, J. Ian Johnson wrote:
IMO, the semantics of if in Coq is terrible. You want to use match
just about anywhere.
There is no difference between an « if » and a « match » construct. The
former is syntactic sugar for the latter. More precisely,
if e return T then u else v
is nothing more than:
match e return T with
| c1 x1 ... xm => u
| c2 y1 ... yn => v
end
where c1 and c2 are the two constructors of the type of e.
On 11/02/2013 21:23, Patricia Peratto wrote:
Is it possible to define an if expression that gives values of
different types in cases true and false?
Maxime has answered to this: you need to use the return clause of a match, or use the bool_rect predicate, which is an instance of it.
Definition bool_rect
(P : bool -> Type) (u : P true) (v : P false) (b : bool) :=
match b return P b with
| true => u
| false => v
end.
It is quite difficult to grasp the typing rule of the dependent match, but the idea is that you in each branch, b is unified with the corresponding constructor. Maybe Chlipala's book is a good thing to start with.
Definition type1 (b:bool) : Set :=
_ifT Set b nat bool.
It is a bad practice to explicitely use the « Set » universe, unless you know what you're actually doing. Just use « Type », or better, don't specify it at all.
But I get the error message Error: In environment b : bool The term
"0" has type "nat" while it is expected to have type "type1 b". The
question is how can I define function1 (using if).
Here O is the constructor of the unary integers, so it is not the type of a type, hence your construction does not type check.
I would write:
Definition _ifT (A B : Type) (b : bool)
(e1 : A) (e2 : B) : if b then A else B
:= bool_rect (fun (b : bool) => if b then A else B) e1 e2 b.
and use it like:
Definition function1 (b:bool) := _ifT bool nat b true 0.
Hope it helps,
PMP
