coq-club - Re: [Coq-Club] Multi-core execution?
  • To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Multi-core execution?
  • Date: Mon, 11 Mar 2013 07:53:26 -0400
On 03/11/2013 06:05 AM, Arnaud Spiwack wrote:
This is an important question. Also a pretty hard one.
The main problem is that tactics are inherently sequential (even with bullets and stuff, because of the existential variables as remarked earlier in this thread). This sequentiality is hard-coded in the type of tactics; very much so in fact. In my branch the situation is actually even worse : the (sequential) state of the proof contains the (partial) solutions for goals (because it handles dependent subgoals as well). So we need to be able to join states at the end of the fork (I hear there is a word for datastructure which support join operations: confluently persistent). My guess, is that given sufficient guarantees on the actual independence of goals and maybe a side of luck, this is a reasonable assumption (the state being essentially a typing and unification environment for existential variables, there is some kind of union on them which works under certain conditions (but bites you in the back quite a bit when they are not met)).
*nod* And I assume that it is not a big deal to make [abstract] provide those "sufficient guarantees," if it doesn't already.
I used to think it was pretty much insurmountable a task, but I'm not so sure any more. With the proviso that without Enrico's aforementioned branch the abstract (and admit) tactic will not work as expected, I will try to hack a prototype (for my branch https://github.com/aspiwack/coq ) such tactical within a few weeks so that we can experiment with it. Or fail trying. And then get back to this thread. Watch for updates.
Excellent! Thanks very much. I'll be quite eager to try it.
