- To: Enrico Tassi <enrico.tassi AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Multi-core execution?
- Date: Sun, 10 Mar 2013 13:56:23 -0400
On 03/10/2013 01:42 PM, Enrico Tassi wrote:
To exploit parallel hardware in OCaml you need some machinery to handle
a pool of already running workers and have an efficient way to transmit
a prover state back and forth. The machinery in question must be
efficient enough to support the granularity of parallelism one wants.
The more fine grained it is, the more efficient the machinery must be.
If I understand well your use case, you want to delegate to slave
processes small jobs. IMO it the most difficult case.
No, I don't think my jobs qualify as small, compared to the time for a UNIX fork(). A majority of my subgoals require a second or more to prove. Some take minutes. So, even an approach based on fork()ing for each subtask could work quite well, I expect. I would expect to see almost perfect improvement in running time, i.e. N cores divides running time by N.
My plan is to begin parallelizing proofs, then sub proofs (assuming the
proof language lets you easily identify independent chunks) and finally,
only if the machinery turns out to be fast enough, tactics.
I'm sorry, but I'm not going to give it a try soon.
Well, my use case of the "parallel semicolon" would only appear as the top-level tactic for a theorem, so perhaps my scenario fits into your "sub proofs" case.
I'll be watching your work in this direction with great interest. Thanks for pursuing it!
- Re: [Coq-Club] Multi-core execution?, (continued)
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Jason Gross, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, AUGER Cédric, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 03/12/2013
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/10/2013
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 03/10/2013
- Re: [Coq-Club] Multi-core execution?, Pierre Courtieu, 03/10/2013
- Re: [Coq-Club] Multi-core execution?, Arnaud Spiwack, 03/11/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 03/11/2013
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/11/2013
