coq-club - [Coq-Club] Coq - String List Sort Lemma
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Coq - String List Sort Lemma
  • Date: Sun, 19 May 2013 13:30:37 +0200
Hello
I have defined a sort function on string list. Now I want to prove a lemma [sort_str_list_same] that if the lists
are equivalent, then sorted lists are equal. I tried induction, but get stuck in the loop.
Please if you help me solving the lemma.
Thanks,
Wilayat
CODE:
Require Import Ascii.
Require Import String.
Notation "x :: l" := (cons x l) (at level 60, right associativity).
Notation "[ ]" := nil.
Notation "[ x , .. , y ]" := (cons x .. (cons y nil) ..).
Fixpoint ble_nat (n m : nat) : bool :=
  match n with
  | O => true
  | S n' =>
      match m with
      | O => false
      | S m' => ble_nat n' m'
      end
  end.
Definition ascii_eqb (a a': ascii) : bool :=
if ascii_dec a a' then true else false.
(** true if s1 <= s2; s1 is before/same as s2 in alphabetical order *)
Fixpoint str_le_gt_dec (s1 s2 : String.string)
 : bool :=
 match s1, s2 with
 | EmptyString, EmptyString => true
 | String a b, String a' b' =>
        if ascii_eqb a a' then str_le_gt_dec b b'
        else if ble_nat (nat_of_ascii a) (nat_of_ascii a')
 | String a b, _ => false
 | _, String a' b' => true
 end.
Fixpoint aux (s: String.string) (ls: list String.string)
 : list String.string :=
 match ls with
 | nil => s :: nil
 | a :: l' => if str_le_gt_dec s a
              then s :: a :: l'
              else a :: (aux s l')
 end.
Fixpoint sort (ls: list String.string) : list String.string :=
 match ls with
 | nil => nil
 | a :: tl => aux a (sort tl)
 end.
Notation "s1 +s+ s2" := (String.append s1 s2) (at level 60, right associativity) : string_scope.
Lemma sort_str_list_same: forall z1 z2 zm,
 sort (z1 :: z2 :: zm) =
 sort (z2 :: z1 :: zm).
Proof with o.
 Admitted.
