coq-club - Re: [Coq-Club] Coq - String List Sort Lemma
  • To: Wilayat Khan <wilayatk AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq - String List Sort Lemma
  • Date: Mon, 20 May 2013 00:20:33 +0200
Am 19.05.2013 21:50, schrieb Wilayat Khan:
Hello Jonas
Hello Wilayat,
FYI here is the end of the file with the lemmas I mentioned and a proof of your property:
Require Import Omega.
Lemma str_lt_antisym s1 s2 : str_lt s1 s2 -> ~ str_lt s2 s1.
induction 1 ; intros B ; inversion B ; auto.
omega.
subst. omega.
subst. omega.
Qed.
Lemma str_lt_antiref s1 s2 : str_lt s1 s2 -> s1 <> s2.
intros H ; induction H ; auto.
discriminate.
injection. intros _ e.
subst. omega.
injection. auto.
Qed.
Lemma str_lt_trans s1 s2 : str_lt s1 s2 -> forall s3, str_lt s2 s3 -> str_lt s1 s3.
induction 1 ; inversion 1 ; auto.
constructor.
constructor.
subst. constructor 2. omega.
subst. constructor 3 ; auto.
Qed.
Fixpoint aux (s: String.string) (ls: list String.string)
: list String.string :=
match ls with
| nil => s :: nil
| a :: l' => if str_lt_ge_dec s a
then s :: (aux a l')
else a :: (aux s l')
end.
Fixpoint sort (ls: list String.string) : list String.string :=
match ls with
| nil => nil
| a :: tl => aux a (sort tl)
end.
Ltac dec_str_lt s1 s2 :=
let H1 := fresh in let H2 := fresh in
destruct str_lt_ge_dec with s1 s2 as [H1|[H1|H1]],
str_lt_ge_dec with s2 s1 as [H2|[H2|H2]];
try (exfalso ; now apply str_lt_antisym with s1 s2);
try (exfalso ; now apply str_lt_antiref with s1 s2);
try (exfalso ; now apply str_lt_antiref with s2 s1);
clear H2.
Lemma sort_same : forall z s1 s2,
aux s1 (aux s2 z) = aux s2 (aux s1 z).
induction z ; intros.
simpl.
dec_str_lt s1 s2 ; subst ; auto.
simpl.
dec_str_lt s1 a ; dec_str_lt s2 a ; simpl.
dec_str_lt s1 a ; subst ; auto.
rewrite IHz with s2 a, IHz with s1 a.
exfalso ; apply str_lt_antisym with s2 s1 ; auto.
apply str_lt_trans with a ; auto.
dec_str_lt s2 a ; subst ; auto.
dec_str_lt a a ; subst ; auto.
now rewrite IHz.
now rewrite IHz.
now rewrite IHz.
Qed.
Note the usage of an Ltac to do most of the heavy lifting for us. The last lemma is not tough to prove - it's just very unhandy. The intuition behind the tactic is: if we already know the result, then we can exclude some cases of str_lt_ge_dec. There are two cases in the proof where my Ltac code is not sophisticated enough to find the contradtion by itself and I need to provide it by hand.
I'm not sure if there is a better proof, i.e., one which doesn't have to try all cases like this one.
Anyway, I hope this was as helpful for you as it was fun for me - I wanted to prove this theorem for quite a while, but I was always too lazy to put down the definitions. Now I had a good reason to :)
Have a lot of fun,
Jonas
