coq-club - Re: [Coq-Club] Coq - String List Sort Lemma
  • To: Wilayat Khan <wilayatk AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq - String List Sort Lemma
  • Date: Sun, 19 May 2013 14:22:27 +0200
Hi Wilayat,
I think it's a good idea to use more expressive functions.
For an example, consider ble_nat.
A better way to write ble_nat is (as in the standard library http://coq.inria.fr/stdlib/Coq.Arith.Compare_dec.html#le_lt_dec ) le_lt_dec:
Definition le_lt_dec n m : {n <= m} + {m < n}.
That way you don't get "true" or "false", which are quite meaningless, but you get "n <= m" or "m < n".
For another,
Definition ascii_eqb (a a': ascii) : {a = a'} + {a <> a'}.
decide equality. Defined.
The way you currently do things you lose any kind of meaning of, e.g., ascii_eqb a a' = true. How do you conclude from such a statement that a = a'?
Next, I suggest proving this on a more general level; i.e., instead of defining sorting for lists of strings, you could define sorting for any type and decidable ordering on that type.
Finally, the theorem you're trying to prove is
aux a (aux b l) = aux b (aux a l)
I believe the reason why you're stuck is that you do not have any meaning of
"str_le_gt_dec".
Therefore you can not tell, e.g., that "
str_le_gt_dec a x = true" and "str_le_gt_dec b x = false" implies "str_le_gt_dec a b = true".
I think your problem is along these lines, even though I'm not sure of the exact statements that you'd need.
If you make the changes as I suggest, I believe the statement will be provable.
Regards, Jonas
Am 19.05.2013 13:30, schrieb Wilayat Khan:
Hello
I have defined a sort function on string list. Now I want to prove a lemma [sort_str_list_same] that if the lists
are equivalent, then sorted lists are equal. I tried induction, but get stuck in the loop.
Please if you help me solving the lemma.
Thanks,
Wilayat
CODE:
Require Import Ascii.
Require Import String.
Notation "x :: l" := (cons x l) (at level 60, right associativity).
Notation "[ ]" := nil.
Notation "[ x , .. , y ]" := (cons x .. (cons y nil) ..).
Fixpoint ble_nat (n m : nat) : bool :=
  match n with
  | O => true
  | S n' =>
      match m with
      | O => false
      | S m' => ble_nat n' m'
      end
  end.
Definition ascii_eqb (a a': ascii) : bool :=
if ascii_dec a a' then true else false.
(** true if s1 <= s2; s1 is before/same as s2 in alphabetical order *)
Fixpoint str_le_gt_dec (s1 s2 : String.string)
 : bool :=
 match s1, s2 with
 | EmptyString, EmptyString => true
 | String a b, String a' b' =>
        if ascii_eqb a a' then str_le_gt_dec b b'
        else if ble_nat (nat_of_ascii a) (nat_of_ascii a')
 | String a b, _ => false
 | _, String a' b' => true
 end.
Fixpoint aux (s: String.string) (ls: list String.string)
 : list String.string :=
 match ls with
 | nil => s :: nil
 | a :: l' => if str_le_gt_dec s a
              then s :: a :: l'
              else a :: (aux s l')
 end.
Fixpoint sort (ls: list String.string) : list String.string :=
 match ls with
 | nil => nil
 | a :: tl => aux a (sort tl)
 end.
Notation "s1 +s+ s2" := (String.append s1 s2) (at level 60, right associativity) : string_scope.
Lemma sort_str_list_same: forall z1 z2 zm,
 sort (z1 :: z2 :: zm) =
 sort (z2 :: z1 :: zm).
Proof with o.
 Admitted.
