- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq - String List Sort Lemma
- Date: Sun, 19 May 2013 23:03:41 +0200
Am 19.05.2013 20:33, schrieb Daniel Schepler:
Personally, I prefer to write comparison operators to be more like Perl's <=> operator. And I don't really like to use { x < y } + { x = y } + { x > y } as the result of this, as the constructors of the different cases are a bit awkward to look at. (And even though that could probably be worked around using notations, the extraction would still have the asymmetrical ugliness.) So I roll my own inductive type "comparison_with_proof" for the result, since I couldn't find any suitable inductive type in the standard library that did exactly what I wanted.
So, this thread inspired me to mock up what proof-carrying comparison operators on ascii and string might look like, in the attached file. A couple points: First, the proofs of vector_lt_irrefl, vector_lt_trans, string_lt_irrefl would probably get bad marks in one of Prof. Chlipala's classes as insufficiently automated... And in more general cases, you'd probably want to allow a general equivalence relation in place of eq for those cases where you're using setoids and you don't want to (or can't) define an explicit quotient type of the setoid.
Daniel Schepler
Hi Daniel,
Why not have something like this (which is the natural extension of + to three types):
Inductive threesum A B C : Type :=
| introA : A -> threesum
| introB : B -> threesum
| introC : C -> threesum
You don't have the asymmetry and it is general enough to support, e.g., other ordering relations.
Nevertheless, I think that a ternary elimination operator (like if for binary types) is really missing.
Nobody wants to write "match ... with introA _ => ... | ... " or "match ... with left (inleft _) => | left (inright _) => ... | _ => ...". Writing "{ lt_eq_lt_dec a b ? e1 | e2 | e3 }" or something would be nicer.
- [Coq-Club] Coq - String List Sort Lemma, Wilayat Khan, 05/19/2013
- Re: [Coq-Club] Coq - String List Sort Lemma, Jonas Oberhauser, 05/19/2013
- Re: [Coq-Club] Coq - String List Sort Lemma, Daniel Schepler, 05/19/2013
- Message not available
- Re: [Coq-Club] Coq - String List Sort Lemma, Jonas Oberhauser, 05/20/2013
