coq-club - Re: [Coq-Club] Computing function results
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Computing function results
  • Date: Mon, 01 Jul 2013 08:31:36 -0400
Has someone suggested before giving proper definitions of your identifiers with [Inductive] and [Fixpoint] rather than [Parameter] and [Axiom]? Coq users tend to be skeptical of any development using axioms in the way that you are. You certainly get much more convenient term simplification doing things more idiomatically. If you _can't_ define your notions constructively, then how are you convincing yourself that they are logically consistent?
On 07/01/2013 05:10 AM,
mtkhan AT risc.uni-linz.ac.at
wrote:
I have the following function definitions of isDDO and isAddo:
Parameter isAddo: addo -> bool.
Parameter isDDO: (list (symbol* (list Z)* (list Z)* symbol)%type) -> Z -> Z
-> (list symbol) -> bool.
Axiom isDDO_def : forall (a:(list (symbol* (list Z)* (list Z)* symbol)%type))
(anzdelta:Z) (anzsigma:Z) (g:(list symbol)),
match a with
| Nil => ((isDDO a anzdelta anzsigma g) = true)
| (Cons e l) => (((isDDOTerm e anzdelta anzsigma g) = true) -> ((isDDO a
anzdelta anzsigma g) = (isDDO l anzdelta anzsigma g))) /\
((~ ((isDDOTerm e anzdelta anzsigma g) = true)) -> ((isDDO a anzdelta
anzsigma g) = false))
end.
Axiom isAddo0 : forall (a:addo), ((isAddo a) = true) -> forall (n:Z),
((0%Z<= n)%Z /\ (n< (length_addo a))%Z) ->
((isAddo_term (get_addo_data a) (get_addo_term a n)) = true).
In the first goal, I simply need to compute the function results
and it should simply work.
