coq-club - Re: [Coq-Club] Computing function results
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: mtkhan AT risc.uni-linz.ac.at
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Computing function results
  • Date: Mon, 1 Jul 2013 15:55:18 +0200
I don't know what you expect: after the first rewrite, your goal becomes
true = isAddo (create_addo tt)
If we take a look at your isAddo0 axiom:
Axiom isAddo0 : forall (a:addo), ((isAddo a) = true) -> forall (n:Z),
((0%Z <= n)%Z /\ (n < (length_addo a))%Z) ->
((isAddo_term (get_addo_data a) (get_addo_term a n)) = true).
It says that IF isAddo a is true, then forall n .....
In your case, you want to prove that isAddo (create_addo tt) is true,
so I don't think you
gave us the correct axiom. Without more context, I don't know to help
you more, sorry.
2013/7/1
<mtkhan AT risc.uni-linz.ac.at>:
> Hi Vincent and Pierre,
> Yea these worked for the isDDO case. What about the other function
> isAddo? Any clue here?
> Thanks.
> taimoor
>> Dear tk,
>> you can try to assert a specialized version of your axiom and then use
>> it to rewrite your goal, something like:
>> assert (HH := isDDO_def nil a1 b0 b).
>> simpl in HH.
>> rewrite HH.
>> I'm pretty sure there is a nicer way to do this, but I don't know it :)
>> Cheers,
>> V.
>> 2013/7/1
>>> Dear Adam,
>>> Thanks for your response. I do agree with you that the selection of
>>> right constructs for defining functions (or any other logical prop)
>>> helps in proving and also to find inconsistency in the theory, if there
>>> is any.
>>> However, I get this proof situation automatically translated from
>>> a verification tool Why3 (http://why3.lri.fr); so in some sense
>>> I have to live with it ;)
>>> So any clue here?
>>> regards,
>>> tk
>>>> Has someone suggested before giving proper definitions of your
>>>> identifiers with [Inductive] and [Fixpoint] rather than [Parameter] and
>>>> [Axiom]? Coq users tend to be skeptical of any development using
>>>> axioms
>>>> in the way that you are. You certainly get much more convenient term
>>>> simplification doing things more idiomatically. If you _can't_ define
>>>> your notions constructively, then how are you convincing yourself that
>>>> they are logically consistent?
>>>> On 07/01/2013 05:10 AM,
>>>> wrote:
>>>>> I have the following function definitions of isDDO and isAddo:
>>>>> Parameter isAddo: addo -> bool.
>>>>> Parameter isDDO: (list (symbol* (list Z)* (list Z)* symbol)%type) ->
>>>>> Z
>>>>> -> Z
>>>>> -> (list symbol) -> bool.
>>>>> Axiom isDDO_def : forall (a:(list (symbol* (list Z)* (list Z)*
>>>>> symbol)%type))
>>>>> (anzdelta:Z) (anzsigma:Z) (g:(list symbol)),
>>>>> match a with
>>>>> | Nil => ((isDDO a anzdelta anzsigma g) = true)
>>>>> | (Cons e l) => (((isDDOTerm e anzdelta anzsigma g) = true) ->
>>>>> ((isDDO a
>>>>> anzdelta anzsigma g) = (isDDO l anzdelta anzsigma g))) /\
>>>>> ((~ ((isDDOTerm e anzdelta anzsigma g) = true)) -> ((isDDO a
>>>>> anzdelta
>>>>> anzsigma g) = false))
>>>>> end.
>>>>> ((0%Z<= n)%Z /\ (n< (length_addo a))%Z) ->
>>>>> In the first goal, I simply need to compute the function results
>>>>> and it should simply work.
