coq-club - Re: [Coq-Club] Computing function results
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: mtkhan AT risc.uni-linz.ac.at
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Computing function results
  • Date: Mon, 1 Jul 2013 15:06:10 +0200
Dear tk,
you can try to assert a specialized version of your axiom and then use
it to rewrite your goal, something like:
assert (HH := isDDO_def nil a1 b0 b).
simpl in HH.
rewrite HH.
I'm pretty sure there is a nicer way to do this, but I don't know it :)
Cheers,
V.
2013/7/1
<mtkhan AT risc.uni-linz.ac.at>:
> Dear Adam,
> Thanks for your response. I do agree with you that the selection of
> right constructs for defining functions (or any other logical prop)
> helps in proving and also to find inconsistency in the theory, if there
> is any.
> However, I get this proof situation automatically translated from
> a verification tool Why3 (http://why3.lri.fr); so in some sense
> I have to live with it ;)
> So any clue here?
> regards,
> tk
>> Has someone suggested before giving proper definitions of your
>> identifiers with [Inductive] and [Fixpoint] rather than [Parameter] and
>> [Axiom]? Coq users tend to be skeptical of any development using axioms
>> in the way that you are. You certainly get much more convenient term
>> simplification doing things more idiomatically. If you _can't_ define
>> your notions constructively, then how are you convincing yourself that
>> they are logically consistent?
>> On 07/01/2013 05:10 AM,
>> wrote:
>>> I have the following function definitions of isDDO and isAddo:
>>> Parameter isAddo: addo -> bool.
>>> Parameter isDDO: (list (symbol* (list Z)* (list Z)* symbol)%type) -> Z
>>> -> Z
>>> -> (list symbol) -> bool.
>>> Axiom isDDO_def : forall (a:(list (symbol* (list Z)* (list Z)*
>>> symbol)%type))
>>> (anzdelta:Z) (anzsigma:Z) (g:(list symbol)),
>>> match a with
>>> | Nil => ((isDDO a anzdelta anzsigma g) = true)
>>> | (Cons e l) => (((isDDOTerm e anzdelta anzsigma g) = true) ->
>>> ((isDDO a
>>> anzdelta anzsigma g) = (isDDO l anzdelta anzsigma g))) /\
>>> ((~ ((isDDOTerm e anzdelta anzsigma g) = true)) -> ((isDDO a
>>> anzdelta
>>> anzsigma g) = false))
>>> end.
>>> Axiom isAddo0 : forall (a:addo), ((isAddo a) = true) -> forall (n:Z),
>>> ((0%Z<= n)%Z /\ (n< (length_addo a))%Z) ->
>>> ((isAddo_term (get_addo_data a) (get_addo_term a n)) = true).
>>> In the first goal, I simply need to compute the function results
>>> and it should simply work.
