- To: Bahman Sistany <bsistany AT yahoo.ca>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] existentially quantified proposition
- Date: Sat, 10 Aug 2013 05:03:04 -0400
Hi,
Although the shape of formula is not exactly what you wanted, an equivalent
formulation would be:
Fixpoint gen (t t' : nat)(n:nat) : Prop :=
match n with
| 0 => True
| 1 => t < t'
| S n' => exists x, t < x /\ gen x t' n'
end.
When n = 4, it generates this formula:
exists x : nat, t < x /\ (exists x0 : nat, x < x0 /\ (exists x1 : nat, x0 <
x1 < t'))
All the "x < y" propositions could also be pushed under the final exists.
But, directly generating in such a form might be complicated because of the
issue of passing arbitrary number of variables recursively. I think a simple
ltac script can transform the the above goal into the desired form.
-- Duckki
On Saturday, August 10, 2013 at 2:15 AM, Bahman Sistany wrote:
> Hi,
> I am trying to come up with an existentially quantified proposition where I
> generate the witnesses (xi's here) and the property
> programmatically/dynamically.
> Fixpoint gen (t t' : nat)(len:nat) : Prop := ???
> (* When len=2, I need: *)
> exists x2, (t < x2 < t')
> (* When len=3, I need: *)
> exists x2, x3 (t < x2 < x3 < t')
> I have been working on various ways of extending 'ex' but nothing works so
> far. Any thoughts on the general problem would be appreciated.
> --Bahman
- [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Duckki Oe, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Rui Baptista, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Adam Chlipala, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
