coq-club - [Coq-Club] Re: repeat inversion ; without infinite looping
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Re: repeat inversion ; without infinite looping
  • Date: Thu, 22 Aug 2013 23:06:11 +0000
I think I have solved this :
https://gist.github.com/anonymous/6313843
via a complete abuse of tactics.
"bad thing" = after inversion,
  * only one term is generated
  * the term that generated is the same as the old term
==> therefore, pose proof (H1 = H2) should type check
whereas, if the newly generated term is different from the old term, then pose proof (H1 = H2) should not type check since H1 and H2 are different terms.
However, if anyone has a cleaner solution, I'd appreciate it too. :-)
On Thu, Aug 22, 2013 at 9:54 PM, t x <txrev319 AT gmail.com> wrote:
Hi,
  I'm trying to design a tactic that inverts everything possible to invert.
  Here is my minimal failure case:
https://gist.github.com/anonymous/6313270
  My current code infinite loops. Two "obvious solutions seems to be"
(1) if there is a way to separate "Consrtructor" from "Function", then, the infinite loop is easy to fix.
(2) If there is a way detect "is result of 'inversion' same as Hypothesis?' --> and force a fail
Can anyone tell me how to do either (1) or (2)?
Thanks!
