coq-club - Re: [Coq-Club] repeat inversion ; without infinite looping
  • To: t x <txrev319 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] repeat inversion ; without infinite looping
  • Date: Sat, 24 Aug 2013 21:03:41 -0400
Line 1 is like [let H := fresh in pose proof (H1 = H2) as H; clear H]; [constr:(H1 = H2)] constructs the term "H1 = H2", and, in doing so, does some form of type checking (not fully, because you can still play games with [appcontext] to break the well-typedness abstraction  So the tactic only succeeds if [H1] and [H2] have the same type.  Similarly, the [unify A B] tactic is the same thing as [idtac] if [A] and [B] are unifiable/convertible (i.e., if [pose proof (eq_refl : A = B)] would succeed), and is the same thing as [fail] otherwise.  (In fact, it's the same, functionally, as [let H := fresh in pose proof (eq_refl : H1 = H2) as H; clear H])
-Jason
On Saturday, August 24, 2013, t x wrote:
Hi Jason,
s
  1) I've actually seen this in either cpdt or ltamer; but I don't understand. Can you explain why this actually works?
https://gist.github.com/anonymous/a38385bd52511864c628
  I understand lines 2 & 3, but I don't see how 1 or 4 works.
  2) I need fail 2 because I have (try (try ... )) so I need "fail 2" to break out of both try's and fail the match.
On Sat, Aug 24, 2013 at 11:53 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Rather than "pose proof (H1 = H2)", you can do one of the following:
[let dummy_check := constr:(H1 = H2) in idtac]
[let T1 := type of H1 in
let T2 := type of H2 in
unify T1 T2]
Also, I think you might want fail 1 (or perhaps even fail 0) rather than fail 2, but I haven't looked too carefully.
-Jason
On Aug 22, 2013 7:06 PM, "t x" <txrev319 AT gmail.com> wrote:
I think I have solved this :
https://gist.github.com/anonymous/6313843
via a complete abuse of tactics.
"bad thing" = after inversion,
  * only one term is generated
  * the term that generated is the same as the old term
==> therefore, pose proof (H1 = H2) should type check
whereas, if the newly generated term is different from the old term, then pose proof (H1 = H2) should not type check since H1 and H2 are different terms.
However, if anyone has a cleaner solution, I'd appreciate it too. :-)
On Thu, Aug 22, 2013 at 9:54 PM, t x <txrev319 AT gmail.com> wrote:
Hi,
  I'm trying to design a tactic that inverts everything possible to invert.
  Here is my minimal failure case:
https://gist.github.com/anonymous/6313270
  My current code infinite loops. Two "obvious solutions seems to be"
(1) if there is a way to separate "Consrtructor" from "Function", then, the infinite loop is easy to fix.
(2) If there is a way detect "is result of 'inversion' same as Hypothesis?' --> and force a fail
Can anyone tell me how to do either (1) or (2)?
Thanks!
