- To: Kristopher Micinski <krismicinski AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] repeat inversion ; without infinite looping
- Date: Sat, 24 Aug 2013 15:37:45 +0000
"crush" has been a ZKPK experience for me -- it proves to me XYZ can be done; but despite having the ltac code, it's so magical that I rarely understand how it is done. :-)
On Fri, Aug 23, 2013 at 1:48 AM, Kristopher Micinski <krismicinski AT gmail.com> wrote:
I don't know about "everything possible" but I will say that this is a basic idea in Chlipala's crush tactic, if you haven't already taken a look at its internals.KrisOn Thu, Aug 22, 2013 at 5:54 PM, t x <txrev319 AT gmail.com> wrote:
Here is my minimal failure case:Hi,I'm trying to design a tactic that inverts everything possible to invert.
https://gist.github.com/anonymous/6313270
My current code infinite loops. Two "obvious solutions seems to be"(1) if there is a way to separate "Consrtructor" from "Function", then, the infinite loop is easy to fix.
(2) If there is a way detect "is result of 'inversion' same as Hypothesis?' --> and force a failCan anyone tell me how to do either (1) or (2)?Thanks!
- [Coq-Club] repeat inversion ; without infinite looping, t x, 08/22/2013
- [Coq-Club] Re: repeat inversion ; without infinite looping, t x, 08/23/2013
- Re: [Coq-Club] Re: repeat inversion ; without infinite looping, Jason Gross, 08/25/2013
- Re: [Coq-Club] Re: repeat inversion ; without infinite looping, t x, 08/25/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, Jason Gross, 08/25/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, Kristopher Micinski, 08/23/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, t x, 08/24/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, gallais, 08/26/2013
