- To: t x <txrev319 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: repeat inversion ; without infinite looping
- Date: Sat, 24 Aug 2013 19:53:29 -0400
Rather than "pose proof (H1 = H2)", you can do one of the following:
[let dummy_check := constr:(H1 = H2) in idtac]
[let T1 := type of H1 in
let T2 := type of H2 in
unify T1 T2]
Also, I think you might want fail 1 (or perhaps even fail 0) rather than fail 2, but I haven't looked too carefully.
-Jason
On Aug 22, 2013 7:06 PM, "t x" <txrev319 AT gmail.com> wrote:
However, if anyone has a cleaner solution, I'd appreciate it too. :-)==> therefore, pose proof (H1 = H2) should type check* the term that generated is the same as the old term* only one term is generatedvia a complete abuse of tactics."bad thing" = after inversion,
whereas, if the newly generated term is different from the old term, then pose proof (H1 = H2) should not type check since H1 and H2 are different terms.
On Thu, Aug 22, 2013 at 9:54 PM, t x <txrev319 AT gmail.com> wrote:
Here is my minimal failure case:Hi,I'm trying to design a tactic that inverts everything possible to invert.
https://gist.github.com/anonymous/6313270
My current code infinite loops. Two "obvious solutions seems to be"(1) if there is a way to separate "Consrtructor" from "Function", then, the infinite loop is easy to fix.
(2) If there is a way detect "is result of 'inversion' same as Hypothesis?' --> and force a failCan anyone tell me how to do either (1) or (2)?Thanks!
- [Coq-Club] repeat inversion ; without infinite looping, t x, 08/22/2013
- [Coq-Club] Re: repeat inversion ; without infinite looping, t x, 08/23/2013
- Re: [Coq-Club] Re: repeat inversion ; without infinite looping, Jason Gross, 08/25/2013
- Re: [Coq-Club] Re: repeat inversion ; without infinite looping, t x, 08/25/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, Jason Gross, 08/25/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, Kristopher Micinski, 08/23/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, t x, 08/24/2013
- Re: [Coq-Club] repeat inversion ; without infinite looping, gallais, 08/26/2013
