- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Sat, 28 Sep 2013 00:43:11 +0530
- Cancel-lock: sha1:Z7vJInq66JO2heqMIaNYeZSciX0=
At 2013-09-28T01:48:07+09:00, Andrej Bauer wrote:
>>The construction in Blass's paper starts with a set Y = {u,v} of
>>cardinality 2. For every proposition P, he defines an equivalence
>>relation R(P) on Y as follows:
>> 1. (u,u) \in R(P)
>> 2. (v,v) \in R(P)
>> 3. P -> (u,v) \in R(P)
>> 4. P -> (v,u) \in R(P).
> This, strictly speaking, is not a definition. You might get one if you
> required R(P) to be the least equivalence relation satisfying the
> above 4 conditions.
Yes, that's true. In my script, I actually defined it as
Inductive blass (P : Prop) : bool -> bool -> Prop :=
| b_0 : blass P true true
| b_1 : blass P false false
| b_2 : P -> blass P true false
| b_3 : P -> blass P false true.
> But it is much easier to define R(P) as
> R(P) = { (x,y) : Y x Y | x = y \/ P }.
> No need for any inductive stuff. Also, Y is just bool.
You mean like
Definition blass' (P : Prop) (x y : bool) : Prop :=
x = y \/ P.
If so, yes, that looks much neater.
> In any case, it is probably useful to learn about setoids, but your
> proof will be, at the end of the day, essentially a proof of decequiv
> -> lem, but packaed up in the setoid technology.
As must be obvious, I am a beginner in Coq. I'm reading Pierce's book
linearly, solving all the exercises. So, if setoids aren't really going
to help me prove deceq -> lem, I'll postpone reading about them.
Regarding quotients, I was wondering if it is possible in Coq to work
with the functor that the quotient set represents instead of working
with the quotient set itself.
What I mean is that given a set Y and an equivalence relation R on Y, we
get a functor F(R) : Sets -> Sets which takes any set A to the set
F(R)(A) of all functions f : Y -> A which are R-invariant (i.e.,
constant on R-equivalence classes). For every element y of Y, we get a
morphism of functors H(R)(y) : F(R) -> Id, where Id is the identity
functor Sets -> Sets. For any set A, the map H(R)(y)(A) : F(R)(A) -> A
is defined by H(R)(y)(A)(f) = f(y).
If two elements y1 and y2 of Y are R-equivalent, then certainly
H(R)(y1)(A)(f) = f(y1) = f(y2) = H(R)(y2)(A)(f),
hence H(R)(y1) = H(R)(y2). Conversely, if H(R)(y1) = H(R)(y2), then
taking A to be the power set of Y, and f : Y -> A to be the function
which maps every element y of Y to its equivalence class R[y], we get
R[y1] = f(y1) = H(R)(y1)(A)(f) = H(R)(y2)(A)(f) = f(y2) = R[y2],
hence y1 and y2 are R-equivalent. Therefore, if X(R) is the "set" of
all morphisms of functors F(R) -> Id, then the function H(R) : Y -> X(R)
which maps y in Y to H(R)(y) separates exactly the R-inequivalent
elements. That is, its fibres are precisely the R-equivalence classes
in Y. So, X(R) could serve as a model for the quotient set Y / R.
I haven't checked the details, and it's possible I've gone over the deep
end here, but if not, and if there's something here that I can formalise
in Coq, that'd be good to know.
Thanks and best regards,
Raghu.
PS : Thanks for the videos! They helped me start using Proof General.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- Re: [Coq-Club] Excluded middle and decidable equality, (continued)
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Andrej Bauer, 09/27/2013
