- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Fri, 27 Sep 2013 11:50:18 +0530
- Cancel-lock: sha1:EBCLcxbO4MKMPQEoGoX5xxOI+Do=
At 2013-09-27T12:33:03+09:00, Andrej Bauer wrote:
> In ordinary mathematics (such as in Blass's paper) we have
> propositional extensionality, which says that logically equivalent
> propositions are equal.
I don't know where propositional extensionality is used in the proof
that I'd summarised of deceq -> lem.
> With that in hand it is easy to finish your exercise without fussing
> with quotients (although I am sure Blass has a good reason to do it
> his way, probably to stick close to set theory):
As I understand it is possible to prove deceq -> lem using setoids as
quotients, without assuming propositional extensionality. I'll try
that.
> Another way to do this without propositional extensionality and
> without quotients is to rephrase deceq so that it says that
> equivalence relations are decidable, not just equality (if we have
> deceq and quotients then it follows that equivalence relations are
> decidable as well):
My goal is to prove deceq -> lem. So I'll still have to prove in Coq
that deceq -> decequiv. It looks like I'll have to use
setoids/quotients for that anyway.
Thanks and best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Andrej Bauer, 09/27/2013
