- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Fri, 27 Sep 2013 16:19:01 +0530
- Cancel-lock: sha1:mBtAfhWX4gfMy6lQjsGqYi+gwHE=
At 2013-09-27T09:43:06+02:00, Arnaud Spiwack wrote:
> Well, not really. You have to change the definition of deceq for the
> proof to pass. Replacing Coq's native equality (which is pretty
> meaningless in the context of setoids) with the setoid equality.
> Which is essentially the same thing as proving decequiv -> lem.
So is there no way to prove in Coq that deceq (with Coq's usual
equality) -> lem?
In any case, I am finding it difficult to understand how to define
setoids in Coq. Here is the relation I am looking at:
Inductive blass (P : Prop) : bool -> bool -> Prop :=
| b_0 : blass P true true
| b_1 : blass P false false
| b_2 : P -> blass P true false
| b_3 : P -> blass P false true.
Given P : Prop, how does one define the quotient bool / (blass P) using
setoids?
Thanks for your help.
Best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Andrej Bauer, 09/27/2013
