- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Fri, 27 Sep 2013 11:42:03 +0530
- Cancel-lock: sha1:zRSTgc10Likr/vVVYrvpiAcuWQo=
At 2013-09-26T17:07:06+02:00, Arnaud Spiwack wrote:
> Coq doesn't have quotients (yet?). So you cannot quite do this
> directly.
> The way to go is to use setoids, that is (dependent) pairs of a type
> and an equivalence relation on that type. Then you have to quantify
> on setoids rather than just types. The equality at each setoid is the
> underlying relation. And quotient is obtained just by changing the
> underlying relation of the setoid.
Thanks for the suggestion. I'll try setoids.
> I'm not sure what reading to suggest for a more in-depth view. Maybe
> the first chapter of my thesis can be of help : http://
> pastel.archives-ouvertes.fr/docs/00/60/58/36/PDF/thesis.spiwack.pdf .
Yes, I'll look at that chapter. Your thesis itself looks very
interesting. It seems to discuss a lot of homological algebra in the
context of Coq.
Best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/26/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Arnaud Spiwack, 09/27/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Andrej Bauer, 09/27/2013
