Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Conor McBride <conor AT strictlypositive.org>
- To: Maxime Dénès <mail AT maximedenes.fr>
- Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se list" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Tue, 7 Jan 2014 17:25:27 +0000
Hi Maxime
On 7 Jan 2014, at 16:56, Maxime Dénès
wrote:
> Still, I don't understand why replacing the pattern matching in my
> example by a call to subst makes the termination check fail.
A call to subst destroys the "proper subterm" status, whereas
pattern matching naively preserves it.
> Maxime.
>> {-# OPTIONS --without-K #-}
>> module BadWithoutK where
>> data Zero : Set where
>> data WOne : Set where
>> wrap : (Zero -> WOne) -> WOne
>> data _<->_ (X : Set) : Set -> Set where
>> Refl : X <-> X
>> postulate
>> myIso : WOne <-> (Zero -> WOne)
>> moo : WOne -> Zero
>> noo : (X : Set) -> (WOne <-> X) -> X -> Zero
>> moo (wrap f) = noo (Zero -> WOne) myIso f
>> noo .WOne Refl x = moo x
moo's input is bigger than the third argument in its noo call
noo's third input is the same as the argument in its moo call
Size-change termination, how are ye?
When you do the translation to eliminators, you're obliged to
show how recursive calls correspond to invocations of the
inductive hypothesis: here that's just not going to happen.
Transporting f across myIso does indeed give an element of
WOne (your Box), but that does not make a nullary inductive
hypothesis any easier to invoke.
I'd quite like to see us defining a type theory in which the
only checking is type checking, then using it as a target for
elaboration. Eliminators are one candidate, but there are
others. Sized types are certainly another strong candidate.
I'm also interested to see whether there are "locally clocked"
explanations for termination, as there seem to be for
productivity.
Interesting times
Conor
>> bad : Zero
>> bad = moo (wrap \ ())
>>> T.
>>>> I am also not sure how specific the problem is to univalence. As Cody
>>>> said, I would expect to find some set-theoretical models where the
>>>> equality holds. So being able to prove the negation is disturbing.
>>>> Maxime.
>>>> On 01/06/2014 07:23 PM, Abhishek Anand wrote:
>>>>> It is known that UIP is inconsistent with univalence.
>>>>> Does this typecheck even after disabling UIP(==K axiom?) ?
>>>>> I might be wrong, but I think that UIP is baked into the typechecker
>>>>> of Agda.
>>>>> But, UIP can be disabled somehow?
>>>>> -- Abhishek
>>>>> http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/%7Eaa755/>
>>>>> On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès
>>>>> <mailto:mail AT maximedenes.fr>>
>>>>> wrote:
>>>>> Bingo, Agda seems to have the same problem:
>>>>> module Termination where
>>>>> open import Relation.Binary.Core
>>>>> data Empty : Set where
>>>>> data Box : Set where
>>>>> wrap : (Empty → Box) → Box
>>>>> postulate
>>>>> iso : (Empty → Box) ≡ Box
>>>>> loop : Box -> Empty
>>>>> loop (wrap x) rewrite iso = loop x
>>>>> gift : Empty → Box
>>>>> gift ()
>>>>> bug : Empty
>>>>> bug = loop (wrap gift)
>>>>> However, I may be missing something due to my ignorance of Agda.
>>>>> It may be well known that the axiom I introduced is inconsistent.
>>>>> Forgive me if it is the case.
>>>>> Maxime.
>>>>> On 01/06/2014 01:15 PM, Maxime Dénès wrote:
>>>>> The anti-extensionality bug is indeed related to termination.
>>>>> More precisely, it is the subterm relation used by the guard
>>>>> checker which is not defined quite the right way on dependent
>>>>> pattern matching.
>>>>> It is not too hard to fix (we have a patch), but doing so
>>>>> without ruling out any interesting legitimate example (dealing
>>>>> with recursion on dependently typed data structures) is more
>>>>> challenging.
>>>>> I am also curious as to whether Agda is impacted. Let's try it
>>>>> Maxime.
>>>>> On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
>>>>> Which bug was this?
>>>>> I only saw the one which allowed you to prove
>>>>> anti-extensionality? But
>>>>> this wasn't related to termination, or?
>>>>> Thorsten
>>>>> On 06/01/2014 16:54, "Cody Roux"
>>>>> <cody.roux AT andrew.cmu.edu
>>>>> <mailto:cody.roux AT andrew.cmu.edu>>
>>>>> wrote:
>>>>> Nice summary!
>>>>> On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
>>>>> Agda enforces termination via a termination
>>>>> checker which is more
>>>>> flexible but I think less principled than Coq's
>>>>> approach.
>>>>> That's a bit scary given that there was an
>>>>> inconsistency found in
>>>>> the Coq termination checker just a couple of weeks ago
>>>>> BTW, has anyone tried reproducing the bug in Agda?
>>>>> Cody
>>>>> This message and any attachment are intended solely for
>>>>> the addressee and may contain confidential information. If
>>>>> you have received this message in error, please send it
>>>>> back to me, and immediately delete it. Please do not use,
>>>>> copy or disclose the information contained in this message
>>>>> or in any attachment. Any views or opinions expressed by
>>>>> the author of this email do not necessarily reflect the
>>>>> views of the University of Nottingham.
>>>>> This message has been checked for viruses but the contents
>>>>> of an attachment
>>>>> may still contain software viruses which could damage your
>>>>> computer system, you are advised to perform your own
>>>>> checks. Email communications with the University of
>>>>> Nottingham may be monitored as permitted by UK legislation.
>>>>> _______________________________________________
>>>>> Agda mailing list
>>>>> Agda AT lists.chalmers.se
>>>>> <mailto:Agda AT lists.chalmers.se>
>>>>> https://lists.chalmers.se/mailman/listinfo/agda
>>>>> Agda mailing list
>>>> Agda mailing list
>>> Agda mailing list
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
