coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • To: Maxime Dénès <mail AT maximedenes.fr>, Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>, "cody.roux AT andrew.cmu.edu" <cody.roux AT andrew.cmu.edu>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
  • Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Wed, 08 Jan 2014 18:46:28 +0100
Maxime, thanks for this nice example! Find it on darcs Agda under
test/succeed/HoTTAndStructuralOrderingIncompatibleMaximeDenes.agda
This is actually fuel on my fire. It shows that the untyped structural termination order works only by accident. It is not the first paradox found in the structural ordering, see e.g. Coquand, Pattern matching..., 1992.
If you look at the Box through the lens of sized types, you cannot reproduce the loop. Without sizes, your postulated isomorphism can fool the structural order. Basically, to go from (Empty -> Box) to Box via the isomorphism would add another wrap constructor, but by going through propositional equality, you can hide this fact from Agda. With sized types, the isomorphism is only between (Empty -> Box i) and (Box (i+1)), which exposes the increase in size when going in the 'to' direction. Here is the Agda code:
{-# OPTIONS --sized-types #-}
open import Common.Size
open import Common.Equality
data Empty : Set where
data Box : Size → Set where
wrap : ∀ i → (Empty → Box i) → Box (↑ i)
-- Box is inhabited at each stage > 0:
gift : ∀ {i} → Empty → Box i
gift ()
box : ∀ {i} → Box (↑ i)
box {i} = wrap i gift
-- wrap has an inverse:
unwrap : ∀ i → Box (↑ i) → (Empty → Box i)
unwrap .i (wrap i f) = f
-- There is an isomorphism between (Empty → Box ∞) and (Box ∞)
-- but none between (Empty → Box i) and (Box i).
-- We only get the following, but it is not sufficient to
-- produce the loop.
postulate iso : ∀ i → (Empty → Box i) ≡ Box (↑ i)
-- Since Agda's termination checker uses the structural order
-- in addition to sized types, we need to conceal the subterm.
conceal : {A : Set} → A → A
conceal x = x
mutual
loop : ∀ i → Box i → Empty
loop .(↑ i) (wrap i x) = loop' (↑ i) (Empty → Box i) (iso i) (conceal x)
-- We would like to write loop' i instead of loop' (↑ i)
-- but this is ill-typed. Thus, we cannot achieve something
-- well-founded wrt. to sized types.
loop' : ∀ i A → A ≡ Box i → A → Empty
loop' i .(Box i) refl x = loop i x
-- The termination checker complains here, rightfully!
Cheers,
Andreas
On 06.01.2014 21:42, Maxime Dénès wrote:
Bingo, Agda seems to have the same problem:
module Termination where
open import Relation.Binary.Core
data Box : Set where
wrap : (Empty → Box) → Box
postulate
iso : (Empty → Box) ≡ Box
loop : Box -> Empty
loop (wrap x) rewrite iso = loop x
gift : Empty → Box
gift ()
bug : Empty
bug = loop (wrap gift)
However, I may be missing something due to my ignorance of Agda. It may
be well known that the axiom I introduced is inconsistent. Forgive me if
it is the case.
Maxime.
On 01/06/2014 01:15 PM, Maxime Dénès wrote:
The anti-extensionality bug is indeed related to termination. More
precisely, it is the subterm relation used by the guard checker which
is not defined quite the right way on dependent pattern matching.
It is not too hard to fix (we have a patch), but doing so without
ruling out any interesting legitimate example (dealing with recursion
on dependently typed data structures) is more challenging.
I am also curious as to whether Agda is impacted. Let's try it :)
Maxime.
On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
Which bug was this?
I only saw the one which allowed you to prove anti-extensionality? But
this wasn't related to termination, or?
Thorsten
On 06/01/2014 16:54, "Cody Roux"
wrote:
Nice summary!
On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
Agda enforces termination via a termination checker which is more
flexible but I think less principled than Coq's approach.
That's a bit scary given that there was an inconsistency found in
the Coq termination checker just a couple of weeks ago :)
BTW, has anyone tried reproducing the bug in Agda?
Cody
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete
it. Please do not use, copy or disclose the information contained in
this message or in any attachment. Any views or opinions expressed by
the author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
may still contain software viruses which could damage your computer
system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
Agda mailing list
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
