coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: Maxime Dénès <mail AT maximedenes.fr>, Conor McBride <conor AT strictlypositive.org>
  • Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se list" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Wed, 08 Jan 2014 09:02:10 +0100
Le 07/01/2014 20:43, Maxime Dénès a écrit :
Hello Conor,
In fact, I was wondering why the call to subst (which is defined by
pattern matching) destroys the proper subterm status, while it is not
the case for pattern matching. It does not seem very uniform, does it?
In Coq, a reduction step would replace subst by its body before
computing the size information.
I agree that elaboration is nice. However, sometimes you don't want to
pay the price for encoding things. In an ideal world, you could prove
the elaboration process correct, and extract a checker that is correct
by construction with respect to the target type theory you mention. Is
there any existing work in that direction?
Maxime.
Hello.
Some time ago, for proving the termination of higher-order rewrite systems, I formalized in Coq the notion of computability closure which is based on an extension of Girard's notion of reductibility. For the moment, it only considers simple types and the syntactic subterm relation in recursive calls. So, there is still quite some work to extend it to richer type disciplines and to size-based termination, but all the basic ingredients are already here (including the semantics of positive inductive types on which size-based termination is based). See http://color.inria.fr/ for downloading the CoLoR library, http://color.inria.fr/doc/CoLoR.Term.Lambda.LCompClos.html for having a look at the development without the proofs, and http://color.inria.fr/doc/CoLoR.Term.Lambda.LSystemT.html to see the example of Gödel' system T.
Best regards,
Frédéric.
On 01/07/2014 12:25 PM, Conor McBride wrote:
Hi Maxime
On 7 Jan 2014, at 16:56, Maxime Dénès
wrote:
Still, I don't understand why replacing the pattern matching in my
example by a call to subst makes the termination check fail.
A call to subst destroys the "proper subterm" status, whereas
pattern matching naively preserves it.
Maxime.
{-# OPTIONS --without-K #-}
module BadWithoutK where
data Zero : Set where
data WOne : Set where
wrap : (Zero -> WOne) -> WOne
data _<->_ (X : Set) : Set -> Set where
Refl : X <-> X
postulate
myIso : WOne <-> (Zero -> WOne)
moo : WOne -> Zero
noo : (X : Set) -> (WOne <-> X) -> X -> Zero
moo (wrap f) = noo (Zero -> WOne) myIso f
noo .WOne Refl x = moo x
moo's input is bigger than the third argument in its noo call
noo's third input is the same as the argument in its moo call
Size-change termination, how are ye?
When you do the translation to eliminators, you're obliged to
show how recursive calls correspond to invocations of the
inductive hypothesis: here that's just not going to happen.
Transporting f across myIso does indeed give an element of
WOne (your Box), but that does not make a nullary inductive
hypothesis any easier to invoke.
I'd quite like to see us defining a type theory in which the
only checking is type checking, then using it as a target for
elaboration. Eliminators are one candidate, but there are
others. Sized types are certainly another strong candidate.
I'm also interested to see whether there are "locally clocked"
explanations for termination, as there seem to be for
productivity.
Interesting times
Conor
