Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Aaron Stump <aaron.stump AT gmail.com>
- Cc: Conor McBride <conor AT strictlypositive.org>, Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Wed, 8 Jan 2014 19:46:43 +0100
On 08.01.14 7:37 PM, Aaron Stump wrote:
Box := mu X. (Empty -> X)
Note that X occurs positively in the body of the mu-type for Box. The
theory gives us a recursor R with this typing rule
b : Box
f : (Empty -> T) -> T
R(b,f) : T
Mmh, why is this the recursor? Should not T depend on (b : Box) or something similar?
This looks like the iterator to me... Maybe that's what you meant...
We certainly have the isomorphism Box = (Empty -> Box) -- it is even a
definitional equality! -- but we cannot use this recursor to write a
term of type Box -> Empty. The best we could do would be to start like
this, where g has type Empty -> Empty, and hence is useless for deriving
Empty.
loop = \ b . R(b, \ g . (g ?))
So I think the wrap constructor being used in Maxime's code is just an
explicit witness of the above implicit isomorphism. Removing it should
not count for structural decrease (obviously).
Where would you locate the structural decrease instead?
Cheers,
Andreas
On 01/08/2014 11:53 AM, Andreas Abel wrote:
Conor,
that's on the latest darcs version of Agda, I guess?
At least my own version of --without-K rejects your match on Refl:
The indices
WOne
X
are not constructors (or literals) applied to variables (note that
parameters count as constructor arguments)
when checking that the pattern Refl has type WOne <-> X
But you say it is justified, is it?
Cheers,
Andreas
On 07.01.2014 17:42, Conor McBride wrote:
Very good. Agda is right and Coq got it wrong. As I said previosuly theNot so fast! The code below is accepted using the --without-K flag, and
definition of loop implicitely uses K.
the elimination that noo does is a based path induction, IIUC.
Conor
{-# OPTIONS --without-K #-}
module BadWithoutK where
data Zero : Set where
data WOne : Set where
wrap : (Zero -> WOne) -> WOne
data _<->_ (X : Set) : Set -> Set where
Refl : X <-> X
postulate
myIso : WOne <-> (Zero -> WOne)
moo : WOne -> Zero
noo : (X : Set) -> (WOne <-> X) -> X -> Zero
moo (wrap f) = noo (Zero -> WOne) myIso f
noo .WOne Refl x = moo x
bad : Zero
bad = moo (wrap \ ())
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Message not available
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Aaron Stump, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/12/2014
