Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Andreas Abel <andreas.abel AT ifi.lmu.de>, Conor McBride <conor AT strictlypositive.org>, Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
- Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Wed, 08 Jan 2014 12:37:42 -0600
Related (I hope) to the discussion of eliminators, I want to point
out that if we were working in a type theory based on positive
recursive types rather than primitive datatypes, this example would
not go through (of course). Empty := mu X.X Box := mu X. (Empty -> X) Note that X occurs positively in the body of the mu-type for Box. The theory gives us a recursor R with this typing rule b : Box f : (Empty -> T) -> T --------------------- R(b,f) : T We certainly have the isomorphism Box = (Empty -> Box) -- it is even a definitional equality! -- but we cannot use this recursor to write a term of type Box -> Empty. The best we could do would be to start like this, where g has type Empty -> Empty, and hence is useless for deriving Empty. loop = \ b . R(b, \ g . (g ?)) So I think the wrap constructor being used in Maxime's code is just an explicit witness of the above implicit isomorphism. Removing it should not count for structural decrease (obviously). Cheers, Aaron On 01/08/2014 11:53 AM, Andreas Abel
wrote:
Conor, that's on the latest darcs version of Agda, I guess? At least my own version of --without-K rejects your match on Refl: The indices WOne X are not constructors (or literals) applied to variables (note that parameters count as constructor arguments) when checking that the pattern Refl has type WOne <-> X But you say it is justified, is it? Cheers, Andreas On 07.01.2014 17:42, Conor McBride wrote:Very good. Agda is right and Coq got it wrong. As I said previosuly the definition of loop implicitely uses K.Not so fast! The code below is accepted using the --without-K flag, and the elimination that noo does is a based path induction, IIUC. Conor {-# OPTIONS --without-K #-} module BadWithoutK where data Zero : Set where data WOne : Set where wrap : (Zero -> WOne) -> WOne data _<->_ (X : Set) : Set -> Set where Refl : X <-> X postulate myIso : WOne <-> (Zero -> WOne) moo : WOne -> Zero noo : (X : Set) -> (WOne <-> X) -> X -> Zero moo (wrap f) = noo (Zero -> WOne) myIso f noo .WOne Refl x = moo x bad : Zero bad = moo (wrap \ ()) |
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Message not available
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Aaron Stump, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/12/2014
