- From: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
- To: Nicolas Magaud <magaud AT unistra.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Question about rewriting with dependent types
- Date: Fri, 10 Jan 2014 07:57:12 -0500
Have you tried the setoid_rewrite tactic?
http://coq.inria.fr/distrib/V8.4/refman/Reference-Manual029.html
On 10 January 2014 06:21, Nicolas Magaud <magaud AT unistra.fr> wrote:
Dear Coq users,
I have a technical question about rewriting with an alternative equality in Coq.
To make it short, I consider a type A (in Set) equipped with any equivalence relation (equal). I do not want to use Leibnitz Equality.
I try to prove a goal (see below) which involves rewriting in the type of an universally quantified variable :
I expect the goal "forall p:(Q x), (R x p)" to be transformed into "forall p:(Q y), (R y p)" when I try to rewrite with an hypothesis "H:equal x y".
This actually works fine when "equal" is Leibnitz equality. But with my equality, I simply lead to an error message which I do not know how to interpret.
Instead, I would have expected the system to tell me about some Proper instances which were missing to do the job correctly.
Is this just a limitation of the current implementation of Coq (I checked with 8.4pl2 and trunk) or simply impossible to obtain with a non-Leibnitz equality ?
Thanks in advance for your suggestions.
Nicolas Magaud
Require Import Setoid Morphisms.
Parameter A:Set.
Parameter equal : A -> A -> Prop.
Parameter Q:A-> Prop.
Parameter R:forall a, Q a->Prop.
Instance equiv_equal : Equivalence equal.
Admitted.
Lemma test : forall x y:A, equal x y -> forall p:(Q x), (R x p).
intros x y H.
rewrite H.
Error: build_signature: no constraint can apply on a dependent argument
- [Coq-Club] Question about rewriting with dependent types, Nicolas Magaud, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Lucian M. Patcas, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Rui Baptista, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Pierre Courtieu, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Dan Frumin, 01/12/2014
