- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
- Cc: Nicolas Magaud <magaud AT unistra.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Question about rewriting with dependent types
- Date: Fri, 10 Jan 2014 17:55:35 +0100
HI Nicolas, you can use a predicate (allDep below) to pack your
pattern to rewrite into something detectable by rewrite. See below.
You can see in section 26.10 of the manual that there are two
"special" such predicate: all and ex that are automatically refolded
when you try to rewrite on Prop ("products in Prop are implicitly
translated to such applications"). But here you cannot use all and ex
but something like allDep. Using a ltac you should be able to perform
the same kind of replacement.
Best,
Pierre
Require Import Setoid.
Require Import Setoid Morphisms_Prop.
Require Import Morphisms.
Parameter A:Set.
Parameter equal : A -> A -> Prop.
Parameter Q:A-> Prop.
Parameter R:forall a, Q a->Prop.
Instance equiv_equal : Equivalence equal.
Admitted.
Definition allDep (Q: A -> Prop) (R:forall a, Q a->Prop) (x:A) :=
forall p:(Q x), (R x p).
Add Parametric Morphism (Q: A -> Prop) (R:forall a, Q a->Prop):
(@allDep Q R)
with signature (equal ==> iff)
as morph.
Admitted.
(* Lemma test : forall x y:A, equal x y -> forall p:(Q x), (R x p). *)
Lemma test : forall x y:A, equal x y -> allDep Q R x.
intros x y H.
rewrite H.
- [Coq-Club] Question about rewriting with dependent types, Nicolas Magaud, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Lucian M. Patcas, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Rui Baptista, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Pierre Courtieu, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Dan Frumin, 01/12/2014
