- To: Nicolas Magaud <magaud AT unistra.fr>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>, "magaud (MAI)" <magaud AT unistra.fr>
- Subject: Re: [Coq-Club] Question about rewriting with dependent types
- Date: Sun, 12 Jan 2014 12:50:30 +0400
> On 10 Jan 2014, at 15:21, Nicolas Magaud
> wrote:
> Dear Coq users,
> I have a technical question about rewriting with an alternative equality in
> Coq.
> To make it short, I consider a type A (in Set) equipped with any
> equivalence relation (equal). I do not want to use Leibnitz Equality.
> I try to prove a goal (see below) which involves rewriting in the type of
> an universally quantified variable :
> I expect the goal "forall p:(Q x), (R x p)" to be transformed into "forall
> p:(Q y), (R y p)" when I try to rewrite with an hypothesis "H:equal x y".
> This actually works fine when "equal" is Leibnitz equality. But with my
> equality, I simply lead to an error message which I do not know how to
> interpret.
> Instead, I would have expected the system to tell me about some Proper
> instances which were missing to do the job correctly.
Right, for the rewrite to succeed you need Q to be a "proper morphism".
That's it, you need it to respect your equality relation, so that "equal"
elements in A get sent to equal elements in Prop.
Probably an axiom like
Proper (equal ==> (=)) Q.
should do that trick. (I am not sure as I don't have access to Coq at the
time I'm writing this email).
You might also want your type A to implement a Setoid class.
The 'Proper' property is defined in Coq.Classes.Morphisms if I remember this
correctly
> Is this just a limitation of the current implementation of Coq (I checked
> with 8.4pl2 and trunk) or simply impossible to obtain with a non-Leibnitz
> equality ?
> Thanks in advance for your suggestions.
> Nicolas Magaud
> Require Import Setoid Morphisms.
> Parameter A:Set.
> Parameter equal : A -> A -> Prop.
> Parameter Q:A-> Prop.
> Parameter R:forall a, Q a->Prop.
> Instance equiv_equal : Equivalence equal.
> Admitted.
> Lemma test : forall x y:A, equal x y -> forall p:(Q x), (R x p).
> intros x y H.
> rewrite H.
> Error: build_signature: no constraint can apply on a dependent argument
- [Coq-Club] Question about rewriting with dependent types, Nicolas Magaud, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Lucian M. Patcas, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Rui Baptista, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Pierre Courtieu, 01/10/2014
- Re: [Coq-Club] Question about rewriting with dependent types, Dan Frumin, 01/12/2014
