coq-club - Re: [Coq-Club] Question about rewriting with dependent types
  • To: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
  • Cc: Nicolas Magaud <magaud AT unistra.fr>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about rewriting with dependent types
  • Date: Fri, 10 Jan 2014 14:54:40 +0000
The setoid_rewrite tactic fails as well. It's not enough for equal to be an equivalence relation. Q and R have to be compatible with equal. I'm not sure how to set up the rewrite tactic to use equal_R.
Axiom A : Set.
Axiom equal : A -> A -> Prop.
Axiom Q : A -> Prop.
Axiom R : forall a, Q a -> Prop.
Axiom equal_refl : forall x, equal x x.
Axiom equal_symm : forall x y, equal x y -> equal y x.
Axiom equal_trans : forall x y z, equal x y -> equal y z -> equal x z.
Axiom equal_Q : forall x y, equal x y -> Q x -> Q y.
Axiom equal_R : forall x y p q, equal x y -> R x p -> R y q.
Lemma test : forall x y : A, equal x y -> forall p : Q x, (R x p).
intros.
assert (q : Q y).
info_eauto 2 using equal_refl, equal_symm, equal_trans, equal_Q, equal_R.
cut (R y q).
info_eauto 3 using equal_refl, equal_symm, equal_trans, equal_Q, equal_R.
On Fri, Jan 10, 2014 at 12:57 PM, Lucian M. Patcas <lucian.patcas AT gmail.com> wrote:
On 10 January 2014 06:21, Nicolas Magaud <magaud AT unistra.fr> wrote:
Dear Coq users,
I have a technical question about rewriting with an alternative equality in Coq.
To make it short, I consider a type A (in Set) equipped with any equivalence relation (equal). I do not want to use Leibnitz Equality.
I try to prove a goal (see below) which involves rewriting in the type of an universally quantified variable :
I expect the goal "forall p:(Q x), (R x p)" to be transformed into "forall p:(Q y), (R y p)"  when I try to rewrite with an hypothesis "H:equal x y".
This actually works fine when "equal" is Leibnitz equality. But with my equality, I simply lead to an error message which I do not know how to interpret.
Instead, I would have expected the system to tell me about some Proper instances which were missing to do the job correctly.
Is this just a limitation of the current implementation of Coq (I checked with 8.4pl2 and trunk) or simply impossible to obtain with a non-Leibnitz equality ?
Thanks in advance for your suggestions.
Nicolas Magaud
Require Import Setoid Morphisms.
Parameter A:Set.
Parameter equal : A -> A -> Prop.
Parameter Q:A-> Prop.
Parameter R:forall a, Q a->Prop.
Instance equiv_equal : Equivalence equal.
Admitted.
Lemma test : forall x y:A, equal x y -> forall p:(Q x), (R x p).
intros x y H.
rewrite H.
Error: build_signature: no constraint can apply on a dependent argument
