coq-club - Re: [Coq-Club] binary operations on types with additional structure
  • To: Daniel Schepler <dschepler AT gmail.com>
  • Cc: "drg AT illinois.edu" <drg AT illinois.edu>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] binary operations on types with additional structure
  • Date: Sat, 18 Jan 2014 08:06:50 +0100
Hi Daniel,
  The reason is Opaque was not respected (or rather understood as really Opaque) by the elaboration/unification, only by the kernel, this will change in the next version (maybe using a Rigid flag instead).
Cheers,
-- Matthieu
Le samedi 18 janvier 2014, Daniel Schepler a écrit :
On a related note, I've tried something like this in the past, and was surprised that it didn't work the way I wanted it to:
Class Plus (A:Type) :=
plus : A -> A -> A.
Instance nat_plus : Plus nat := Peano.plus.
Definition nat_copy : Type := nat.
Hint Opaque nat_copy : typeclass_instances.
Instance nat_copy_plus : Plus nat_copy := Peano.plus.
Definition zero1 : nat := 0.
Definition zero2 : nat_copy := 0.
(* Want the Hint Opaque to cause this to fail but it works. *)
Check (plus zero1 zero2).
(What I actually wanted to use it for was to declare an opposite category as OpCat C := C and force it to use the opposite Hom, id, comp instead of the ones from the original category when objects were declared of type OpCat C.)
Daniel Schepler
On Fri, Jan 17, 2014 at 11:06 AM, <drg AT illinois.edu> wrote:
One way to implement the notion of group G (for example) would be as a record,
the first element of which is the type X of the elements of the group.  The
multiplication operation could be defined with something like
   Definition op {G:Group} (g:pr1 G) (h:pr1 G) := ... .
where pr1 is projection on the first component.  If pr1 is defined as a
coercion,
then it can be written more suggestively as
   Definition op {G:Group} (g:G) (h:G) := ... .
If G' is another group sharing X with G, but not the other data, and g : G and
g' : G', then " op g g' " will be well-typed, which is mathematically
surprising
and might lead the user astray.
Assuming this issue has already been encountered in the past, I wonder what
the best solution is.  I'm tempted to say that an element g of G should be
defined
to be a pair (G,x) with x:X, and the coercion would then be the one that sends
G
to the type of such pairs.  This would be mathematically pleasing, as elements
of groups would know to which group they belong, just as elements of a type
"know" to which type they belong.
The actual situation where this arose was with two objects of a category and
the type of isomorphisms between them.
-- Matthieu
