coq-club - Re: [Coq-Club] binary operations on types with additional structure
  • To: Bas Spitters <b.a.w.spitters AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] binary operations on types with additional structure
  • Date: Sun, 19 Jan 2014 10:18:53 -0500
Correct me if I'm wrong, but I'm under the impression that type classes can
be useful for letting coq guess what group an object is in, but it doesn't solve
the ambiguity that I point out: that there will be confusion if a type
is the type of elements of two groups.
On Sun, Jan 19, 2014 at 9:16 AM, Bas Spitters <b.a.w.spitters AT gmail.com> wrote:
Dear Dan,
We collected some references on this at the Institute:
http://uf-ias-2012.wikispaces.com/Type+classes
Best,
Bas
On Fri, Jan 17, 2014 at 8:06 PM, <drg AT illinois.edu> wrote:
One way to implement the notion of group G (for example) would be as a record,
the first element of which is the type X of the elements of the group.  The
multiplication operation could be defined with something like
   Definition op {G:Group} (g:pr1 G) (h:pr1 G) := ... .
where pr1 is projection on the first component.  If pr1 is defined as a
coercion,
then it can be written more suggestively as
   Definition op {G:Group} (g:G) (h:G) := ... .
If G' is another group sharing X with G, but not the other data, and g : G and
g' : G', then " op g g' " will be well-typed, which is mathematically
surprising
and might lead the user astray.
Assuming this issue has already been encountered in the past, I wonder what
the best solution is.  I'm tempted to say that an element g of G should be
defined
to be a pair (G,x) with x:X, and the coercion would then be the one that sends
G
to the type of such pairs.  This would be mathematically pleasing, as elements
of groups would know to which group they belong, just as elements of a type
"know" to which type they belong.
The actual situation where this arose was with two objects of a category and
the type of isomorphisms between them.
