- To: drg AT illinois.edu
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] binary operations on types with additional structure
- Date: Sun, 19 Jan 2014 15:16:09 +0100
Dear Dan,
We collected some references on this at the Institute:
http://uf-ias-2012.wikispaces.com/Type+classes
On Fri, Jan 17, 2014 at 8:06 PM, <drg AT illinois.edu> wrote:
One way to implement the notion of group G (for example) would be as a record,
the first element of which is the type X of the elements of the group. The
multiplication operation could be defined with something like
Definition op {G:Group} (g:pr1 G) (h:pr1 G) := ... .
where pr1 is projection on the first component. If pr1 is defined as a
coercion,
then it can be written more suggestively as
Definition op {G:Group} (g:G) (h:G) := ... .
If G' is another group sharing X with G, but not the other data, and g : G and
g' : G', then " op g g' " will be well-typed, which is mathematically
surprising
and might lead the user astray.
Assuming this issue has already been encountered in the past, I wonder what
the best solution is. I'm tempted to say that an element g of G should be
defined
to be a pair (G,x) with x:X, and the coercion would then be the one that sends
G
to the type of such pairs. This would be mathematically pleasing, as elements
of groups would know to which group they belong, just as elements of a type
"know" to which type they belong.
The actual situation where this arose was with two objects of a category and
the type of isomorphisms between them.
- [Coq-Club] binary operations on types with additional structure, drg, 01/17/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel Schepler, 01/18/2014
- Re: [Coq-Club] binary operations on types with additional structure, Matthieu Sozeau, 01/18/2014
- Re: [Coq-Club] binary operations on types with additional structure, Vladimir Voevodsky, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel R. Grayson, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Bas Spitters, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel Schepler, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Arnaud Spiwack, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Jason Gross, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Bas Spitters, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel R. Grayson, 01/20/2014
