- To: Bas Spitters <b.a.w.spitters AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] binary operations on types with additional structure
- Date: Sun, 19 Jan 2014 12:27:06 -0500
Good points, all.
Actually, Bas, I'm not sure 1*2 is a good example of what I wanted to disallow. A good example
would be a category C and its opposite C^op, which have the same objects. But after the
discussion it seems it's better to write Hom_C(c,c') or Hom_(C^op)(c,c'), rather than to
write Hom(c,c'), in which C is filled in automatically. As Vladimir says, implicit parameters should
be uniquely determined.
On the other hand, obeying that would mean jettisoning the standard mathematical notation
f : c --> c' for declaring f to be a morphism from c to c', because there C is filled in automatically.
Hmm.
On Sun, Jan 19, 2014 at 11:20 AM, Bas Spitters <b.a.w.spitters AT gmail.com> wrote:
BasBest,As Gabriel says, one usually tries to solve the opposite problem.In your approach it seems that you want disallow "1*2" as 1 and 2 are really in (Z,+), not to be confused with 1 and 2 which are in (Z,*) ?What one solves using canonical structures or type classes is the diamond inheritance problem.Sorry, I was in a hurry.Such a problem usually comes up with Rings which are semigroups (and monoids) in two ways.
On Sun, Jan 19, 2014 at 4:18 PM, Daniel R. Grayson <drg AT illinois.edu> wrote:
Correct me if I'm wrong, but I'm under the impression that type classes canbe useful for letting coq guess what group an object is in, but it doesn't solvethe ambiguity that I point out: that there will be confusion if a typeis the type of elements of two groups.On Sun, Jan 19, 2014 at 9:16 AM, Bas Spitters <b.a.w.spitters AT gmail.com> wrote:
BasBest,Dear Dan,
We collected some references on this at the Institute:
http://uf-ias-2012.wikispaces.com/Type+classesOn Fri, Jan 17, 2014 at 8:06 PM, <drg AT illinois.edu> wrote:
One way to implement the notion of group G (for example) would be as a record,
the first element of which is the type X of the elements of the group. The
multiplication operation could be defined with something like
Definition op {G:Group} (g:pr1 G) (h:pr1 G) := ... .
where pr1 is projection on the first component. If pr1 is defined as a
coercion,
then it can be written more suggestively as
Definition op {G:Group} (g:G) (h:G) := ... .
If G' is another group sharing X with G, but not the other data, and g : G andthe best solution is. I'm tempted to say that an element g of G should be
g' : G', then " op g g' " will be well-typed, which is mathematically
surprising
and might lead the user astray.
Assuming this issue has already been encountered in the past, I wonder what
defined
to be a pair (G,x) with x:X, and the coercion would then be the one that sends
Gto the type of such pairs. This would be mathematically pleasing, as elements
of groups would know to which group they belong, just as elements of a type
"know" to which type they belong.
The actual situation where this arose was with two objects of a category and
the type of isomorphisms between them.
- [Coq-Club] binary operations on types with additional structure, drg, 01/17/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel Schepler, 01/18/2014
- Re: [Coq-Club] binary operations on types with additional structure, Matthieu Sozeau, 01/18/2014
- Re: [Coq-Club] binary operations on types with additional structure, Vladimir Voevodsky, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel R. Grayson, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Bas Spitters, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel Schepler, 01/19/2014
- Re: [Coq-Club] binary operations on types with additional structure, Arnaud Spiwack, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Jason Gross, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Bas Spitters, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Daniel R. Grayson, 01/20/2014
- Re: [Coq-Club] binary operations on types with additional structure, Arnaud Spiwack, 01/22/2014
