- To: Jeremy Avigad <avigad AT cmu.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coercing equality proofs
- Date: Tue, 28 Jan 2014 16:51:20 -0500
Good point. Here is how to do it using propositional extensionality.It should be possible to do using the "bracket type" projection Type -> Prop but I am not sure how exactly it works in Coq since I do not use Prop.
V.
(Sorry for the lousy proof scripts. I have been away from Coq for a while.)
Best wishes,
Jeremy
Axiom prop_ext: forall (p q : Prop), (p <-> q) -> p = q.
Section Test.
Variables a b : Prop.
Variable p : @eq Type a b.
Definition bracket (A : Type) : Prop := forall (P : Prop), (A -> P) -> P.
Lemma bracket_eq (x : Prop): bracket x = x.
apply prop_ext.
split.
intro H.
apply (H x).
intro H1. apply H1.
intros H P H1.
apply (H1 H).
Qed.
Lemma coerce: @eq Prop a b.
transitivity (bracket a).
symmetry. apply bracket_eq.
transitivity (bracket b).
rewrite p. reflexivity.
apply bracket_eq.
Qed.
End Test.
V.
On Jan 28, 2014, at 2:30 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
There is no way without axioms. Going the other way is straightforwad: "match (H : @eq Prop x y) in (_ = y') return (@eq Type x y') with eq_refl => eq_refl end". It does not work going the other way because y' would be a Type, and you'd be trying to make it a Prop. If you think about this homotopy-theoretically (google homotopy type theory), there is no guarantee that every point along a path @eq Type_i (x : Type_j) (y : Type_j) will be small enough to fit into a Type_j. You could do it with Axiom K, I believe.
-Jason
On Jan 28, 2014 1:06 PM, "Leonardo de Moura" <leonardo AT microsoft.com> wrote:
Hi,
Given (x y : Prop), I’m wondering about how to coerce an equality proof for (@eq Type x y) to (@eq Prop x y).
Is this possible?
Thanks,
Leo
- [Coq-Club] coercing equality proofs, Leonardo de Moura, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Jason Gross, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Vladimir Voevodsky, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Jeremy Avigad, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Cody Roux, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Bas Spitters, 01/29/2014
- Re: [Coq-Club] coercing equality proofs, Arnaud Spiwack, 01/29/2014
